Author Topic: First attempt, a DIY shunt resistor  (Read 2033 times)
Offline TenoTopic starter
  • Country: ar
« on: September 22, 2019, 08:46:03 pm »
Hello there!
Firt try at creating a simple shunt resistor.
Beside using some specific wire, just made one using common materials.
I'm happy, it works!
Is 1mv per 100mA.
Now I wnat to buid another one.
Wich material should I use?
Cheers from Argentina!
https://otroblogdemarcelo.wordpress.com/2019/09/21/shunt/
Offline joeqsmith
Re: First attempt, a DIY shunt resistor
« Reply #1 on: September 22, 2019, 09:05:18 pm »
I have no idea what your "common" materials are but you may want to consider something more stable than copper.
https://www.quora.com/Why-are-alloys-like-constantan-and-manganin-used-for-making-standard-resistors
Here is a link where I was attempting to make my own.
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/msg1168820/#msg1168820
Offline MagicSmoker
« Reply #2 on: September 22, 2019, 10:01:50 pm »
A proper shunt resistor will be made of manganin (or, less commonly, constantan) because these alloys have relatively high bulk resistivity and a near-zero temperature coefficient of resistance, but you can get decent results with stainless steel. The tempco of stainless steel isn't zero, but it's much lower than mild steel and doesn't corrode/rust.
For example, a 1mm diameter 316SS wire that is 10.61cm long will have a resistance of 0.100 Ohms (bulk resistivity of 74 microOhms-cm).
The following users thanked this post: Teno
  • Country: ar
« Reply #3 on: September 22, 2019, 10:45:16 pm »
Common= stainless steel wire
Cannot have access to any suitable material other than kanthal, bring any to Argentina is quite hard
