Author Topic: How do I wire up this connector?  (Read 2490 times)
Offline belaBartokTopic starter
« on: August 28, 2012, 08:44:57 am »
I am not so experienced yet with kinds of connectors and how to wire them together.  I have been playing with molex stuff a little...so...I bought these 8pin connectors the other day from a surplus store.  I got them home and realized I had no idea how to wire them up.  I destroyed 1 of them trying various methods.   They have "Panduit" embossed in the plastic.  I went to the panduit site...couldn't really find anything to help me.  Any thoughts?  Thank you in advance.
Offline amyk
Re: How do I wire up this connector?
« Reply #1 on: August 28, 2012, 09:25:09 am »
There are special crimping tools for these but a blunt rod of suitable diameter should work for punching the wire into the metal prongs.
Offline Psi
« Reply #2 on: August 28, 2012, 09:45:45 am »
The wire should be pushed in with insulation still on. The metal forks will cut the insulation and make contact.
You can try a general telecommunication punch-down tool, but i suspect its a special tool
Offline David_AVD
« Reply #3 on: August 28, 2012, 10:27:35 am »
I think I bought ours from Digikey.  It's similar to this one from memory:
http://www.digikey.com/product-detail/en/0638133504/WM5151-ND/2327986
When you find the connectors on the Digikey site, they often list the matching tool on the product page.
« Reply #4 on: August 28, 2012, 03:32:44 pm »
I have had reasonable success using a thin bladed screwdriver ( Quante tooling is an arm and a leg, and I am not going to buy it for use once or twice a year) to push the wire between the blades. Otherwise a cheap Krone or clone network tool will probably do the job.
« Reply #5 on: August 28, 2012, 08:21:05 pm »
Thanks for all the info.   I will definitely order some from digi-key so I KNOW they match.   I suppose I have a more general question would be; what are some good, reasonably priced connectors for standard pin headers one should have on hand for slapping something together?  Thanks again.
