Author Topic: First big op amp design, does it look like it will work?  (Read 2018 times)
Offline ConnorGamesTopic starter
« on: August 08, 2012, 04:46:03 am »
     Could you please look over this schematic and tell me if it will work (assuming the right signals are applied to p1 by the MCU/ADC board. It's my first circuit of this scale, so I wanted to get a second opinion on it before I hit the "buy" button.
      Schematic(KiCad):
                 http://dl.dropbox.com/u/11366066/LdPSU.sch
      Design goals(not set in stone, I know the low current range accuracy will probably not be that good):
                 http://dl.dropbox.com/u/11366066/DesignCriteria.txt
      Image is below:
      Thanks a bunch - Connor!
