Author Topic: First oscilloscope  (Read 3941 times)
Offline ChrishasTopic starter
First oscilloscope
« on: October 24, 2020, 12:18:44 am »
Hi, I've started going into electronics and as I'm reading a book called "Basic Electronics: Theory and Practice" one of the tools used is a scope. I'd like to do some audio projects in the future such as pedals and synth modules and also learn to repair stuff. I've been browsing ebay but a lot of the scopes I see here(uk) seem barely tested, there's barely any info about some brands/ models and in general hard to tell if sth is worth it. ie theres a hitachi v555(50MHz) for £95 but not sure how old it is, is it worth it over some hameg hm205-2 or 203-5? I'm trying to avoid anything missing probes, or which they don't have at least a couple pictures of it working.
Apologies if this seems vague but I see a lot of different opinions in different posts/forums. For example 20Mhz or less isnt good for some stuff, or if a scope is too old it may require a lot of time in repairs.
Thanks in advance for any info,
Chris
Offline ataradov
    • Personal site
Re: First oscilloscope
« Reply #1 on: October 24, 2020, 12:37:01 am »
There are a ton of threads on this topic. With varying opinions on whether analog scopes are useful anymore. No matter what you do, in modern days you will face digital signals, for which you would want to have a DSO.
I would add a bit more money and get a cheaper digital scope. There are a ton of decent options starting from $250 and even less in some cases.
As far as the probes go - they are a wear item and supposed to be replaced. Probes you will get with 30 year old scope are going to be garbage and will need replacement anyway. And really good probes are now really cheap that it is not really worth worrying about.
Alex
The following users thanked this post: rsjsouza
Offline george.b
  • Country: br
« Reply #2 on: October 24, 2020, 12:48:03 am »
Hello, and welcome to the forum.
The HM205-2 is a combiscope with a 5MSa/s digitizer, which should suffice for capturing audio waveforms, but not much else. Both Hamegs have 20 MHz (analog) bandwidth, which is plenty for audio.
The Hitachi has cursors, which are a useful thing to have, not to mention way higher bandwidth, but it doesn't allow you to freeze a waveform on the screen.
The HM203-5 has, IMO, no redeeming features in comparison to the other two. The component tester seems like a gimmick to me.
It depends on which feature set you think will serve you better.
If you can go for a modern DSO, do that instead.
Offline james_s
« Reply #3 on: October 24, 2020, 12:51:04 am »
The Hitachi scopes are fairly nice for the era. I would not bother with a 20MHz analog scope unless somebody offers it to you for free. It's better than nothing, but it's not worth what it would cost to ship, unless you're really going for the nostalgia aspect.
Offline rstofer
« Reply #4 on: October 24, 2020, 01:06:02 am »
Search for Charlotte.  We had a LONG thread a couple of weeks ago.  People’s opinions won’t have changed.  She’s in Switzerland,
Offline Wallace Gasiewicz
« Reply #5 on: October 24, 2020, 01:07:09 pm »
Chris:
I do not know much about prices in UK. I had a real nice "school" Tek scope a few years ago. It was only 15 Megs but had a big screen and was very good at low audio freq.
I sold it for maybe $20. Cannot keep everything. (I suppose I'll be kicked out of TE anonymous for that last statement)
Wally
Offline akimpowerscr
« Reply #6 on: October 24, 2020, 01:55:51 pm »
Hello and welcome to the forum.
We went to the moon thanks to analog oscilloscopes and suddenly it seems that an analog oscilloscope is no longer of any use, not even for a beginner.  :-DD
You say what you want to do:
"I'd like to do some audio projects in the future such as pedals and synth modules and also learn to repair stuff."
An analog oscilloscope is fine for what you want to do, maybe better than a DSO because it is easier to use and the component tester is very useful for repair.
But there are pitfalls to avoid:
- only buy an oscilloscope in good working order, never a broken device.
- buy only a simple oscilloscope, without cursor, without readout, and without excessive sophistication.
More sophisticated it is, more risk of failure.
- Give preference to oscilloscopes with component tester, it is very useful in repair.
For the probes, it is mainly wear accessories, it is better to buy new ones.
We find 60 or 100Mhz probes on ebay for a few tens of euros.
The price of analog oscilloscopes is often less than the price of repairing any device and allows you to take the risk of a possible breakdown ... In this case, the device is sold as defective and we buy another one .... the harm is very low.
What are my recommendations?
HAMEG: Made simple and rugged oscilloscopes in the past often with a built-in component tester.
The best choice in my opinion is the HM605 (60Mhz with component tester) but it becomes hard to find in good working order.
- HM 203: highly recommended (all versions)
- HM204: all versions
Avoid HM3XXs and newer HAMEG's, they are not very reliable.
TEKTRONIX: the most famous manufacturer of analog oscilloscopes:
I recommend the 465B (100Mhz) provided it is in good working order.
Also the 2235 although the 22xx series is less robust than the 465. (Mostly problems with power supply.)
Finally, why not mention it despite being rare, the Hewlett Packard HP1740A which is splendid but takes up a lot of space on the table. It must also be in perfect working order.
Offline HB9EVI
« Reply #7 on: October 24, 2020, 02:12:40 pm »
the 'better' is the enemy of the 'good'
It took myself a while till I was ready to go into DSOs; the final exitus of my Tek2230 was the punch over the line, and I never regretted it.
If it's turning about a recommendation for beginners, I start to think if it's really a good idea advising the purchase of old hardware.
That's not so much a question, if those devices are still valuable - certainly they are - BUT a newbie has practically no chance of fixing one of those older scopes, even if nobody doubts the quality of an old Tek or Hameg - they still can fail. Then what? If there's nobody at hand who can help out repairing for a convenient price it's turning in a 100% lost for the owner + frustration.
« Reply #8 on: October 24, 2020, 02:28:03 pm »
The better is not the most sophisticated, it is the tool that is making what you need to do and that is simple to use.
For repair or for audio projects, a DSO is far too sofisticated, too much useless options....
Why obsess over failures? The risk is low, there are simple model analog oscilloscopes (not TEK 2465 .... !!) which have been working for decades without failure and which will certainly work for another ten years.
The problem is that on the forums we only talk about broken oscilloscopes, not about the thousands of others which continue to function perfectly.
« Last Edit: October 24, 2020, 02:34:39 pm by akimpowerscr »
Offline HB9EVI
« Reply #9 on: October 24, 2020, 02:42:40 pm »
that's your point of view
a DSO is as intuitive to operate as an old fashioned CRO; the software featured addons can be used but they don't have to; maybe once you're glad to have a basic FFT function or an averaging; it can also help you out as a quite accurate frequency counter aso...
unless it's a real bargain and not a big loss in case of a final defect, there is no reason to still recommend CROs for beginners.
personally I was getting tired repairing my old hardware, never mind if test equipment or ham radios; and even if you repair it, nobody can assure that a Tek from the 80' is going to run another 10 years. I threw out my old Teks and Hamegs, also the good old FT-736; I really got tired of struggling ever and ever again in a new mess when I just wanted to do something else.
If you spend more time maintaining your equipment than working on your projects, something is wrong. Maybe I've had an unlucky hand with my vintage devices, but since they're gone, I have time doing that what I want and spend much less time troubleshooting my working horses.
« Last Edit: October 24, 2020, 02:50:33 pm by HB9EVI »
The following users thanked this post: tautech, george.b
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #10 on: October 24, 2020, 02:54:38 pm »
Well, depends on the audio. Digital audio (more and more proeminent these days) can greatly benefit from the DSO "useless" features. Repair of car radios can also be made more difficult if you have one of these digital amplifiers tightly coupled with the main MCU. Vaccuum tube audio usually benefits from the higher input voltage tolerance of much older oscilloscopes (equally made with vaccuum tubes) but a great deal of repairs require just signal tracing, which can be made using other methods. This is far from a comprehensive list of "audio" applications, but it is broad enough that it can't be put under the same umbrella.
Regarding the years of use of an older oscilloscope: sure, they have been working for years now but there is always a tradeoff between repairability (harder on a more modern oscilloscope) versus chances of actually needing the repair (higher on an old oscilloscope).
IMO, I also am on the field of the first three responders: preferrably go for a new DSO due to the longer usability in the field, or get an old analog oscilloscope if it works and can be had for very minimal price. Another alternative is if you can find a used Rigol DS1052E or DS1102E in pristine condition for relatively low money (maybe $100, but that depends on the used market) - these lack the added features of more modern DSOs but are very well built and very usable.
Offline rstofer
« Reply #11 on: October 24, 2020, 04:00:39 pm »
If you scour eBay for scopes, and there are hundreds, watch out for shipping.  It is very likely that the shipping is as much or more than the scope.
I really recommend reading ALL of Charlotte's thread because every conceivable argument is made, over and over.  It's not until Reply 150 that she goes all in on a 200 MHz 2 Channel Siglent SDS 1202X-E which is an excellent choice.
https://www.eevblog.com/forum/beginners/what-an-oscilloscope-recommended-for-a-woman-passionate-about-electronics/150/
There a lot of discussion leading up to that point.
But the real fun starts AFTER she buys the Siglent and works through the User Manual, point by point.  The thread is a long read but there are some really useful experiments.  Many of the experiments simply can't be done on an analog scope.  FFT, Integration, Measurements, Single Shot and so on.  These features belong to the DSO.
Offline george.b
  • Country: br
« Reply #12 on: October 24, 2020, 04:18:33 pm »
Again - gimmick feature. Functionality that can be replicated externally for pennies with an old transformer and a couple of components shouldn't be considered as a selection criterion for an oscilloscope.
« Reply #13 on: October 24, 2020, 04:35:38 pm »
This is not true at all.
Compare the simplicity of the controls of an HM203 with all of the menus and submenus of a DSO.
A DSO is not intuitive at all .... You have to spend days studying the manual while on an analog oscilloscope, there is almost nothing to learn to be able to use it.
An example: the trigger options of a DSO: a real headache for a beginner.
« Reply #14 on: October 24, 2020, 04:42:30 pm »
The fact that the component tester is integrated into the oscilloscope is a great advantage ...
No need to disconnect the probes and plug in the BNC cables from the external device.
In addition, DSO's do not work well in XY
« Last Edit: October 24, 2020, 04:44:30 pm by akimpowerscr »
Offline wizard69
« Reply #15 on: October 24, 2020, 06:42:00 pm »
As already mentioned lots of great threads on this subject.    In simple terms any scope is netter than no scope!!!!   For audio work there is no reason not to use and analog scope.   The trick is to buy a working unit.
If you intend to work on digital based synths, then you "might" need a higher end modern scope.    I'm of the opinion though that you don't need a high end and expensive scope to get started in audio work.
I'm trying to convert that to Yankee bucks but I have to think that 95 is a bit high for that era scope.  Hitachi made decent scopes so if it is in good condition it might be worth it.
I believe you are holding probes to a standard they are not worthy of.   Consider any probes supplied with a used instruments as garbage until proven otherwise.   Probes of all types are wear items and need to be inspected regularly and replaced as needed.    Inspection should be at every use if you get involved in high voltage work, I always give my probes a quick review at work when working on high voltage stuff.   It is very much a save your ass practice.
Frankly you often see people in the industry being foolish about probes.    I'm not sure why this attitude exists because probes are relatively cheap and frankly are of higher quality than most of the old stuff out there.   Even with audio work safety needs to be considered!
The interesting thing about repairs is that they are also learning opportunities.   Repairing a scope for a business or even a focused hobby might not make sense but as a way to expand your electronics repair experience fixing an analog scopes is a skills builder.   This assume you can get prints and the like for the scope.   Learning with out the prints is more of a struggle.
When considering bandwidth the first thing to realize is that you don't need a lot of bandwidth for audio work.   This especially when focused on the analog end of the business.   Now given that you are better off going well outside of the audio band.   For audio work you can even consider some of the USB based instruments.    USB based instruments like Analog Discovery generate a lot of opinions so that might be another discussion.
Chris
The trick when starting out is to find the right balance of dollar outlays.    Personally if you are about to buy something new, as a beginner, I'd go with a good quality bench multimeter.   This assumes that you can find a decent scope to get by with for a couple of years.    The reason is a good bench meter will beat out the best handheld meter you can buy as far as ease of use on an electronics work bench.   One handed operation and an easy to read screen are two of the bigger reasons to go with a bench DMM.   Also consider that bench multimeters have a range of functions that didn't even exists on bench meters in the 1970's.
Of course if you can't find a decent used scope you may have to apply more of you budget to a new scope.   You don't want to be without one.    It is just that I don't like using handheld DMM on the work bench.
« Reply #16 on: October 24, 2020, 09:33:20 pm »
I would like to add some information that might be useful.
For the repair of analog synthesizers, it is sometimes necessary to adjust the frequency of oscillators.
We could do this by using a function generator with digital reading and using the XY fonction of the oscilloscope.
With the Lissajous pattern, you can get a precise adjustment but it is quite touchy for frequencies of 1Khz and higher.
Another method would be to use an inexpensive vintage frequency counter or a cheap kit from ebay.
I use an old HP5315A ... The frequency counter does not need to have high accuracy or a high frequency bandwith.
One advantage that the HM204 has over the HM203 is that it has a Y output on the rear panel.
This makes it possible to connect the frequency counter to it and to be able to constantly read the frequency of the signal displayed on the screen.
« Last Edit: October 24, 2020, 09:35:33 pm by akimpowerscr »
Offline nigelwright7557
    • Electronic controls
« Reply #17 on: October 24, 2020, 11:33:12 pm »
I have got by with a 20MHz analogue scope for about 10 years now in my own business.
I designed stuff upto about 20MHz so its fine for that.
I do a lot of audio and that is we  lwithin its limits.
Paid £40 off ebay for it as its second channel isnt working properly.
You really need to think about what you are going to use a scope for.
Thats will give yo ua bandwidth and scope type to go for.
My sig gen is about 10 years old to oand paid £20 for that on ebay.
Fancy soldering station ? No, £10 soldering iron from Maplin that goes on forever and a tip lasts about a year.
Offline HB9EVI
« Reply #18 on: October 25, 2020, 09:33:52 am »
again, that's your point of view
except for the specs, I never really bothered even taking a look into the manual
if you talk about the trigger options, you already talk about something, what a classical CRO doesn't even have - more than an edge trigger you don't get there, and even on the DSO as a standard setting I use most of the time that type of trigger.
the way you talk, one might have the impression you never really bothered trying out a DSO
Offline pwlps
« Reply #19 on: October 25, 2020, 09:37:56 am »
I had many analog scopes and liked them but I switched to DSOs when I realized how useful it can be to see the signal before the trigger.
PS. At the time they appeared I remember I was very impressed by this apparent causality violation in DSOs, today none of my students has ever asked about how it works  :)
« Last Edit: October 25, 2020, 10:24:53 am by pwlps »
« Reply #20 on: October 25, 2020, 10:36:05 am »
I don't think you can put yourself back in the place of a beginner.
Follow RSTOFER's advice and read the 32 pages of Charlotte's topic which masterfully demonstrates the difficulties a beginner encounters with a DSO
« Reply #21 on: October 25, 2020, 10:49:39 am »
Totally useless to learn basic electronics and "to do some audio projects in the future such as pedals and synth modules and also learn to repair stuff;"
Offline pwlps
« Reply #22 on: October 25, 2020, 11:31:03 am »
Possibly yes, still, it is not useless to know about it. And in "repair stuff" it might be useful depending on the "stuff" in question :P
Offline HB9EVI
« Reply #23 on: October 25, 2020, 12:20:05 pm »
I followed that topic for a while; I guess you should be able to admit, that the aptitude to get into a new matter, heavily depends on the individual learning curve. Charlotte wanted to progress quite fast, understanding the things also on the basic physical-mathematical level and not only reduced on the operation of the device itself. From my point of view that's the way it should go.
also I have to say, that the limited digital capabilities of my old Tek2230 were trickier to understand and use in meaningful way than it ever was on my DSOs.
still:
if one can get hands on a CRO for a few bucks, sure, why not? but I consider it useless to spend 100s of bucks for a state-of-the-art CRO from 1975 and then end up in disappointment, if something on that device is going to fail. I got already too often in conversations with other hams, who bought old gears and ended up with a lot of frustration, if those beauties stopped working. No newbie is able to fix more than a few basic things, not even on an old analog CRO from the 70ies. Not to talk about, that I have a bad feeling seeing beginners pick in a CRO maybe not being aware, where to better leave the fingers out due to high voltage.
Offline CharlotteSwiss
« Reply #24 on: October 26, 2020, 09:17:04 am »
I cannot make a comparison between digital and analog oscilloscope (never used an analog); I can however say that the digital one really performs many functions, maybe even too many! But with patience and studying the manual well you learn everything; in my spare time I have been studying my siglent 1202 for more than 3 months, now I am at the end of the study and I have learned almost all its potential; to solve some problems it gives you more possibilities, but if you don't study them all you will always use the usual ones without going further.
As a beginner I had quite a hard time learning all the functions, some I understood immediately others it took me weeks (the difficult ones are all analyzed in my topic).
For the choice of a DSO I would recommend brands like siglent or rigol, they make good products at human prices; the first thing you will have to face will be what bandwidth you might need and especially if you need 4 channels, in my topic this aspect is analyzed in the first pages ..
Good choice!
