Author Topic: LT1764 adjustable current source  (Read 849 times)
Offline XgNTopic starter
  • Country: lt
« on: January 19, 2022, 06:05:01 pm »
Hi guys,
Wanted to implement adjustable current source which is shown in LT1764 LDO datasheet https://www.analog.com/media/en/technical-documentation/data-sheets/1764fb.pdf at page 16. The only change I did that placed OPA196 (higher min supply voltage and lower offset currents) instead of LT1366. But the output current is not adjusting only a ~50 miliamps at some point on R1 potentiometer. The output current is always at maximum according to the load/supply voltage. Is this schematic true? Seems interesting feedback capacitor C3 instead of a resistor. Or something else here I'm missing.
Offline Capernicus
Re: LT1764 adjustable current source
« Reply #1 on: January 19, 2022, 06:26:49 pm »
Just use a good ol' potentiometre.    8)
  • Country: lt
« Reply #2 on: January 19, 2022, 06:36:33 pm »
The potentiometer in position R1 is brand new, 1k multiturn. As for CC source would like to push to the limits for transients and try to achieve a a few of ten microseconds stable constant current pulse at the output. The problem that this schematic is not working at all so far.
Offline porter
« Reply #3 on: January 19, 2022, 07:39:27 pm »
I think the external op amp completes the feedback using the regulator via the sense/adj pin.
"SENSE (Pin 5/Pin 6): Sense. For fixed voltage versions of
the LT1764 (LT1764-1.8/LT1764-2.5/LT1764-3.3), the
SENSE pin is the input to the error amplifier"
Offline KT88
« Reply #4 on: January 19, 2022, 08:09:57 pm »
Just a stupid question: did you check the inverting and non-inverting inputs of the amplifier - I tend to exchange them accidentally from time to time just to annoy myself...
  • Country: lt
« Reply #5 on: January 20, 2022, 03:11:24 pm »
Double-checked a few times..
The error amplifier should be inside LDO and yes, this is the input pin to it. So far as I understand they decided to make another 1.2V reference and change "sensed" voltage according to the drop on the shunt. Nevertheless, in this schematic the non-inverting input of the opamp always gets power supply voltage (e.g. +5V) and not that 1.2V which was intended. Also the opamp should be in unity gain mode or something.
Online SiliconWizard
« Reply #6 on: January 20, 2022, 08:33:43 pm »
Just the LTSpice simulation. It's absolutely horrible. It starts at the max current (> 3 A) and takes a long time to settle, time which depends on R1 setting... and was not able to get lower than ~957 mA.
Haven't investigated it much more than this.
