Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Oscillator with 4060 counter
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Oscillator with 4060 counter (Read 5709 times)
michaelym
Regular Contributor
on:
June 24, 2013, 06:25:03 am »
I first built this circuit (Attached) with HEF4060BP and it worked perfectly.
When I built it with a SN74HC4060 it doesn't work and I cannot figure out why.
Michael
Logged
duskglow
Guest
Re: Oscillator with 4060 counter
Reply #1 on:
June 24, 2013, 06:39:33 am »
What is your supply voltage?
Logged
michaelym
Regular Contributor
Reply #2 on:
June 24, 2013, 07:06:45 am »
3.6-4.2V
Logged
duskglow
Guest
Reply #3 on:
June 24, 2013, 07:15:01 am »
I would check the specifications of each. A cursory look tells me they have slightly different characteristics and the HC might react differently to that voltage then the HEF.
Logged
michaelym
Regular Contributor
Reply #4 on:
June 24, 2013, 08:07:27 am »
Weird, I just tried it with a 4MHz oscillator and it works.
Logged
thesgoat
Contributor
Reply #5 on:
June 24, 2013, 08:51:40 am »
I had exactly the same issue with a 32kHz crystal, ended up making a separate oscillator out of a spare inverter.
Logged
Alana
Frequent Contributor
Country:
Reply #6 on:
June 24, 2013, 09:22:39 am »
Tried wihout resistors?
Logged
michaelym
Regular Contributor
Reply #7 on:
June 24, 2013, 09:32:22 am »
Yes, I tried it without resistors and also with lower value resistors 2.2k & 100k.
Logged
Alana
Country:
Reply #8 on:
June 24, 2013, 11:50:28 am »
Is there any reason not to use 4000b series chip instead of 74hc series? 4000b chip works and with same Vcc it should be compatible with rest of circuit if you use 74HC chips there.
Logged
michaelym
Regular Contributor
Reply #9 on:
June 24, 2013, 03:07:57 pm »
I tried it with CD74HC and it works.
If I can figure out why it's not working with the SN74HC, maybe I can find a solution that only involves replacing passives, and avoid throwing out all the chips.
Last Edit: June 25, 2013, 11:51:54 am by michaelym
Logged
michaelym
Regular Contributor
Reply #10 on:
June 25, 2013, 11:52:47 am »
I mixed up the part numbers in the last reply, now it's correct.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
