Author Topic: Copper trace thickness/width calculation?  (Read 4124 times)
Offline The Magic RabbitTopic starter
« on: September 19, 2015, 09:28:35 pm »
I'm making my first copper board. Is there a formula to calculate how thick I should make a track based on the power? Most of it is either 5V or 12V at less than 10mA but there are a few tracks that will be carrying 12V at up to 2A, from the FETs.
Sent from my XT1039 using Tapatalk
Offline Farley
Re: Copper trace thickness/width calculation?
« Reply #1 on: September 19, 2015, 09:53:47 pm »
Try this site:
http://www.4pcb.com/trace-width-calculator.html
It has javascript calculators and also shows the formulas used if you scroll down a bit.
« Reply #2 on: September 20, 2015, 03:04:54 pm »
Thanks!
Offline waspinator
« Reply #3 on: April 08, 2016, 06:51:33 pm »
Try this site:
Why does only current matter in the calculations? if I have 30V at 1A it suggest a 30mil trace, or 1V at 30A, isn't the same amount of power dissipated?
Offline johansen
« Reply #4 on: April 08, 2016, 06:54:19 pm »
power loss is resistance times amps squared.
Offline Kilrah
« Reply #5 on: April 08, 2016, 06:55:13 pm »
P=RI^2.
R depends on your trace, all that's left is current.
Voltage plays no role in the heating part of it.
The following users thanked this post: waspinator
Offline Neilm
« Reply #6 on: April 08, 2016, 07:16:01 pm »
The track is carrying the same amount of power - it is not dissipating that power. The power that is dissipated is the small voltage drop you will have along that trace. Making the trace wider will reduce the resistance of the trace and hence reduce the voltage drop.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline fubar.gr
  • Country: gr
    • Fubar.gr
« Reply #7 on: April 09, 2016, 09:51:37 am »
Another very good PCB calculator is Saturn PCB Toolkit: http://www.saturnpcb.com/pcb_toolkit.htm
When specifying trace width you have to take into account
1) what is the max desired temp rise above ambient and
2) what is the max voltage drop you can tolerate
Sometimes the only way to fullfil the above requirements within a specific PCB area will be to either use a heavier copper PCB or add more solder and/or external copper wire.
