Author Topic: Best Way To Test Capacitors With A Multimeter?  (Read 1650 times)
Offline JakeCTopic starter
    • Nitrous Junkie Drag Race Team
« on: October 20, 2013, 10:22:31 am »
I am attempting to repair our old TV. When you turn it on the backlight only stays on for about a second. After some research I believe it is one of the caps, I have read about using the ohms range to charge the cap then measuring it with volts DC. Is this the best way?
Thanks
Jake
Drag Racer, Computer Geek, and Electronics Fanatic
Offline DL8RI
Re: Best Way To Test Capacitors With A Multimeter?
« Reply #1 on: October 20, 2013, 11:04:33 am »
at first I would try a visual inspection, normally the Caps are visually damaged.
Charging the caps (any battery does the job, you don't have to use the Ohm-Range) and discharging them via the input-impedance of your DMM would do, then you have to calculate your time-constant (tau=RC) and so on... They have to be desoldered first!
Faulty caps normally have a big difference in Capacity (nF instead of µF), so this method may be accurate enough, but this is kinda annoying. Maybe it's time for a new DMM, even the cheaper ones have a C-Measurement build in.
Another type of diagnostic is the ESR, I'm not sure if the new DMMs can measure this (mine can't).
alm
  • Guest
« Reply #2 on: October 20, 2013, 11:23:00 am »
In general ESR is a better diagnostic of failed caps in switching power supplies than capacitance. I don't know of any DMM that can measure ESR, you would generally look at LCR meters or dedicated ESR meters (e.g. the Bob Parker design). I don't see how you'd improvise an ESR measurement with just a DMM, in general you'd use a function generator and oscilloscope for that. Forum user krypton2035 has collected a bunch of DIY ESR meter schematics on his website.
