Author Topic: Flat power resistor  (Read 4050 times)
Offline sensoTopic starter
  • Country: pt
    • My AVR tutorials
Flat power resistor
« on: June 11, 2015, 09:48:24 am »
Good morning, looking for another component, this time I'm on the look for flat power resistors, the idea is to make a big heated plate to remove broken digitizers from tablets and laptops, my idea was to use the typical cylindrical power resistor that have a built in heat-sink(photo attached in the end).
But given that the aluminium slab will have around 30x40cm those would be too localized I think, so I tried to find some nice big planar power resistor, like the ones that are used in this type of hot plate:
http://www.aliexpress.com/item/free-shipping-high-quality-LCD-separator-Machine-Hot-Plate-for-Screen-Glass-Repair-iPhone-5-Galaxy/1278138825.html
I have one and the resistors are two rectangular pieces, each half the size of the heat-plate, but I can't find anything as big as those at Mouser/Digikey/Farnell.
Any ideas where to find big power resistors, the total heating power needs to be around 1-1.5kW for fast heating, the max temperature needed is just 80ÂșC.
Online PA0PBZ
Re: Flat power resistor
« Reply #1 on: June 11, 2015, 10:43:30 am »
Offline Cliff Matthews
    • General Repair and Support
« Reply #2 on: June 11, 2015, 11:18:12 am »
Remove handles, clamp on a thick sheet of aluminum, and you're in business with a 10amp Variac (adjustable auto-transformer).
Use a thermal probe to find Variac's sweet spot for it. It's a nice piece of kit for any bench..
Offline matseng
    • My Github
« Reply #4 on: June 11, 2015, 02:39:13 pm »
Those planar resistors are expensive! (almost as much as the unit specified). I suppose if one does a lot of this type of repair, that unit is worth it then.. Along-side all the micro tools, molybdenum cutting wire and special pastes, it's not too pricey.
Online tszaboo
« Reply #5 on: June 11, 2015, 02:57:57 pm »
A reel of 1206 is like 6 eur, and a two sided PCB this size must be cheap at the local manufacturers. Bonus if you integrate the temperature controller in the middle. Get an intern to solder it.
Offline zapta
« Reply #6 on: June 11, 2015, 03:22:42 pm »
What's your target temperature?      Is it to desolder or just to loose glue?
Offline mikerj
« Reply #7 on: June 11, 2015, 04:33:53 pm »
Maybe a contact grill element would be useable?
Offline N2IXK
« Reply #8 on: June 11, 2015, 04:42:51 pm »
Since it is a pure resistive load, a simple (and cheap!) incandescent lamp dimmer is all you need to control that thing.  No need for a big expensive variac to do it.
"My favorite programming language is...SOLDER!"--Robert A. Pease
« Reply #9 on: June 11, 2015, 05:18:40 pm »
True, but I'll take the Variac since it can be used on a thousand other issues  8)
Offline electr_peter
  • Country: lt
« Reply #10 on: June 11, 2015, 05:47:03 pm »
If low temp is enough, search for "car/bus/truck mirror heater".
Offline firehopper
« Reply #11 on: June 11, 2015, 08:07:12 pm »
what about heated beds for 3d printers?
« Reply #12 on: June 11, 2015, 10:11:37 pm »
..given that the aluminium slab will have around 30x40cm those would be too localized I think
Thick aluminum spreads heat evenly. Spread out 6 pasted 50-ohm 50-watt resistors wired in series with thermal sensing at the center and it should be quick enough at both 120 and 240v. I still think a flat pan is best on $$... You've just got to control the temp, have fun!
