I just bought a new multimeter; VolcraftR VC830. Because I'm beginner in electronics and I am only 13 years old and I can not afford one of the fluke multimeters I'm asking people for some advices if this VC830 is good or not.
Description:
A new series multimeters manufacturer Voltcraft ®. Rugged, reliable, with practical equipment, ergonomic design, safe for the user - these are all features of this professional multimeter. This multimeter is synonymous with safety. Special casing construction makes it lightweight for battery and fuse open only when the device you are separated from all measuring leads. Built-in function TLD ® (TDL = Test Lead Detection) alerts the user in the measurement incorrectly connected cables. For input voltages> 30 V appears on the display warning symbol. The unique concept of security can help with the following features: robust casing with sprayed soft-rubber protection, 1,000 W power fuses with the ability to separate and 30 kA switching impedance by pressing reduces the input resistance for the prevention of erroneous measurement results arising from loss of voltage. Among the standard equipment also includes an optical interface. The device is for measuring the overvoltage category CAT IV 600 V and CAT III 1000 V and has been tested in accordance with EC 61010th.
Specifications:
Measuring range capacity: 0.01 nF - 4000 microF
Weight: 380 g
Basic accuracy of ± 0.5%
Measuring range AC amps: 0.1 microA - 10 A
Optical Interfaces
Dimensions: (W x H x D) 91 x 185 x 43 mm
Power supply: 9 V battery
Calibration possible according to ISO / DKD
Measuring Range DC amps: 0.1 ?A - 10 A
Measuring range DC voltage: 0.1 mV - 1000 V
Measuring category: CAT IV 600 V, CAT III 1000 V
Measuring frequency range: 10 Hz - 10 MHz
Measurement ? range: 0.1 ? - 60 MOhm
Display: 6000 counts
Measuring range: AC voltage 1 mV - 750 V
~Asdwjure
