Is there a simple circuit that takes a pulse input (either ground or VCC) and causes a flip flop to flop and then the same input again to flop again ie no reset but still have Q and inverted Q outputs. This would be for a button to invert the outputs (so hardware debounce would be helpful too) and having Q and inverted Q means you could attach to the relevant one in order to select the correct default condition.
