Author Topic: Flir HS-307 HS-324 thermal Imager H series disc to set time stamp  (Read 101 times)
Offline TechnosalTopic starter
Hello all I need some help. I just repaired a Flir HS-307 it had a bad micro display, bad clock battery and I could not locate a hot shoe for it so I did some mods to it and installed power and video out jacks on the top to power it externally and get video out without the hot shoe, see pics. My unit has firmware version 3.07. I need the H series disc that comes with these to set the timestamp does anybody have this disc and can you please put it up on cloud share or something similar so I and many others with the same problem can set our clocks? If so please include a link on here.  The hs series disc or hm series disc should work the firmware should be the same. Also if anybody has the firmware 3.09 please put it up these are really nice thermal imagers and we all want to set our clocks and update, please help.
Best Regards
Sal
