Author Topic: Multirotor motor durability / continuous used as fan?  (Read 2623 times)
Offline sam1275Topic starter
« on: November 16, 2014, 07:01:30 pm »
Hello everyone, I have an idea of using multirotor motor as a fan, because it's small, brushless, very powerful, and good at controlling the speed, but I have a few questions about this:
1. Is it OK to use them as a long-term powered fan? Most multirotors will fly for just 10-20 minutes and have a rest, so will it shorten the life if I power it on for a few hours without stopping, or even 24*7?
2. If it's fine to run them continuously, then what is the MTBF of a good motor, such as DJI or so? I cannot find this specification online.
Thank you for any helping!
Offline mzzj
Re: Multirotor motor durability / continuous used as fan?
« Reply #1 on: November 16, 2014, 08:12:56 pm »
Bearings are usually the weakest link and those can last anything between 0.1 and 10000 hours. This is also depends how well your prop is balanced.
I wouldn't use  for anything even partly critical.
Offline BradC
« Reply #2 on: November 17, 2014, 10:37:31 am »
No. Those motors are designed for intermittent use and will just smoke up and die if you run them continuously. There is no ventilation and the bearings are too small to conduct any heat away from the armature/commutator.
I've got several heli's (both multi and single rotor) and I killed my first one by flying it back to back with several batteries in a row. Now I have several of each model and rotate them and the batteries. This allows the motors time to cool down between runs.
« Reply #3 on: November 17, 2014, 12:26:23 pm »
Thank you everyone!
Offline ivan747
« Reply #4 on: November 17, 2014, 02:52:17 pm »
Well, they are burshless  ;)
Doesn't take that much to try one. You should put the prop so that it directs airflow into the motor, and use a prop that actually blows air to the motor.
Put the ESC in the way as well.
And of course, derate the motor a lot. :-+
Tell me about the results because I'm curious  ::) ;D
Offline BradC
« Reply #5 on: November 18, 2014, 01:18:52 am »
My bad. I missed that entirely. All mine are brushed and its the brushes that are the weak point.
