Something's missing: no source or load impedance has been defined, I think? So the Q is infinite in all cases!
In practice, there are, well, about as many Q's as there are impedances you can rub together -- you don't have to take just the intrinsic component Q -- but there are two in particular that are of significant note.
Component Q: the Q of the two-terminal element itself. Real inductors and capacitors have some amount of resistance, and this defines the Q of the component itself.
By example, notice that the Q of a resonator (as a two-terminal LC component) goes to zero at resonance: its reactance cancels out, presenting just resistance, and so the Q is zero by definition. This might seem at odds with intuition (surely a resonator has some Q defined by the quality of its resonance?), but serves to illustrate we must be careful with our definitions.
And for that case, when we do have a 2-terminal component with some poles in its impedance: we might wish to use another definition of Q, like the bandwidth of a resonant peak or trough. Thus we disregard the terminal impedance, understanding that the component has some internal structure that isn't so well defined by instantaneous impedance alone.
Alternately, we might craft a basic model of the component, around a frequency of interest, and consider the Qs of those representative elements. This can result in some quite peculiar values (consider the microscopic C and ludicrous L of a quartz crystal equivalent circuit!), but gives a correct answer within the scope of that model (i.e., the, whatever xxH inductor, plus 100Ω-ish ESR, gives the, whatever 100k-odd Q factor we find so useful).
The other important definition is system Q. Say we take a 1uH 1Ω inductor and connect it in series between two 50Ω ports (source and load). The series circuit has 101 ohms total resistance and 1uH inductance, giving a -3dB point of ~16MHz. At the corner frequency, X_L = R, so the system Q is 1 at this point. At passband frequencies, Q << 1, and stopband, Q >> 1 (rising eventually towards component Q). Note that, in the pass and transition bands, component Q affects insertion loss and sharpness, and system Q has a hard ceiling of component Q (you can't connect any (positive) resistors around a component and get a higher Q than its internal resistance dictates!).
So, I think as your transfer functions are lacking any source or load resistance, Q cannot be defined -- there also cannot be any well-defined power transfer in such a system, at least, finite nonzero amounts for all [finite nonzero] frequencies (I think?).
