Author Topic: fluorescent tubes and ambient temperature  (Read 571 times)
Offline hl68fxTopic starter
« on: January 30, 2020, 12:37:49 am »
Hi everyone,
I would like to use fluorescent tubes in some kind of furnace. Can you tell me what happens to these lamps being used in an ambient temperature of 80 to 100 °C?
What happens to light output and lifespan? Will it be possible at all?
Kind regards
Tom
Offline Jwillis
Re: fluorescent tubes and ambient temperature
« Reply #1 on: January 30, 2020, 01:20:22 am »
Fluorescent tubes are very sensitive to ambient temperatures .Light output drops off significantly either direction of 25 to 30 degrees centigrade. For example  exterior lamps go very dim at -20C and again grow dim in very hot  areas.Different Types can be effected differently by ambient temperature.http://www.lamptech.co.uk/Documents/FL%20Temperature.htm and http://www.lamptech.co.uk/Documents/Journals/Thorn%20Lighting%20Journal%203.pdf do a better job of explaining this.
Online amyk
« Reply #2 on: January 31, 2020, 02:32:03 am »
I recommend using incandescent if you need it to withstand high temperatures --- lightbulbs are much hotter than that inside.
The following users thanked this post: I wanted a rude username
Offline CatalinaWOW
« Reply #3 on: January 31, 2020, 02:58:30 am »
Another choice is to use a light pipe to bring light in from whatever source floats your boat.  Glass fibers and pipes will easily handle the temperatures you mention.
