Author Topic: Flux Pen for beginner ?  (Read 11867 times)
Offline JanJansenTopic starter
« on: August 05, 2017, 02:34:47 pm »
Hi, i have 10 parts that are SOP package, i also ordered 10 converters from ebay,
Now i was looking in youtube, they use flux or a flux pen, then i see the warnings on the pen.
Hazard statements
Safety instructions
P210Keep away from heat, hot surfaces, sparks, open flames and other ignition sources. No smoking.
P233Keep container tightly closed.
P261Avoid breathing dust/fume/gas/mist/vapours/spray.
P280Wear protective gloves/protective clothing/eye protection/face protection.
P313Get medical advice/attention.
P337If eye irritation persists: see safety data sheet.
P403Store in a well-ventilated place.
Do i really need this to solder the SOP package ?, glad its no SSOP btw ( o no, SOP packages are being faded out of production ).
What do you suggest instead ?,
i also saw these DIY flux on youtube, they mix rasin or arabic gum with alcohol.
How can they say : P210Keep away from heat, hot surfaces, sparks, open flames and other ignition sources. No smoking.
while i have a hot soldering iron in the other hand ?
Should i lay it on the roof ?, i have no real laboratory with air cleaning or i dont know what they want.
Are you serious ?, those people in youtube dont even has that.
What can go wrong with these pens ?
I rather solder without.
You use that pen ?
thanks
aliexpress parachute
Offline agehall
Re: Flux Pen for beginner ?
« Reply #1 on: August 05, 2017, 02:50:04 pm »
You don't need flux pens, but you'll want flux of some sort.
Stay away from home-made crap. Just buy whatever you can get your hands on - any flux is better than no flux.
I'm pretty sure the warning mostly relates to open flames and ignition sources.
No, just be aware that there are vapours coming off the pen when you use it. Sitting in a confined space with no ventilation all day long while soldering is not a good idea.
Are you serious!? Tons of people, including me use protective gear when soldering. I always wear gloves nowadays, especially since I often work with leaded solder.
Unless you act like a total d**k when using them, not a whole lot.
Have you ever compared soldering with and without flux? I would never want to solder anything without flux if I have an option to use it.
Offline R005T3r
« Reply #2 on: August 05, 2017, 02:57:47 pm »
Actually, flux pens are very useful tools for hand soldering, because when you start using flux pens, you won't go back, since it improves your soldering results drammatically. Not to mention that SMD soldering would very tricky whitout flux.
All the hazardous statements are made to discourage pepole to use them whitout proper fume extraction system because flux burns and it makes smoke (actually, when ever you put some solder on the tip of your iron, you get some smoke. That smoke is the flux contained into the wire). In my opinion, if you have a fume extractor (don't have to be professional, a PC fan whit some carbon filters or something like that will be enought) you are good to go.
Also, remember to clean your soldering bench when you finish soldering. useless to say but don't eat on your soldering bench/room.... Another tip to avoid fumes exposure would be keeping the fan closest possible to soldering area and remember that your face should NEVER be reached by fumes. You need to do something like this, to put it simple:
Home-made fluxes can be done, but the results are poor. Tried by myself.
« Reply #3 on: August 05, 2017, 03:30:17 pm »
I also use leaded solder, i do wash my hands, is that not enough ?
Also where do you store such a pen in a well ventilated area ?
And thanks Rooster, i will look for such a fume extractor system,
i noted these pens also state you cannot use it near electrical gear ?, hmz.
Ok, so no DIY flux then.
Suppose i try with using alcohol only ?, let me guess : no good.
The following users thanked this post: Sceadwian
Offline Nusa
« Reply #4 on: August 05, 2017, 03:35:17 pm »
Flux makes life easier. It doesn't have to be in pen form, however. Syringes work fine too.
DIY fluxes if done right do work ok...it's just more trouble than it's worth to save a couple bucks.
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #5 on: August 05, 2017, 03:40:48 pm »
Flux removes the oxidation from what you're soldering. You should always use it.
Personally I like the MG Chemicals 835:
http://www.mgchemicals.com/products/prototyping-and-circuit-repair/pens/rosin-flux-835-p
I also use a Hakko FA-400:
http://www.hakko.com/english/products/hakko_fa400.html
But many people use the type R005 showed in the image.
Offline helius
« Reply #6 on: August 05, 2017, 04:25:34 pm »
The advice to use personal protective equipment is because flux is a sensitizer and some users in production environments (40H/week) develop chemical sensitivity or allergy to it. I have not heard any stories of this happening to hobbyists. So you do not need to use gloves to handle flux, it is simply cover-your-ass for when you allow employees at assembly plant to not use gloves and then they sue for work related disability.
You should not inhale flux smoke, but many people for decades have used the technique of holding their breath until the smoke is away. In a large space with drafts or good ventilation, smoke extraction equipment is not a necessity. In a production environment with many workers in the same room, it is needed.
« Last Edit: August 05, 2017, 04:31:32 pm by helius »
Offline agehall
« Reply #7 on: August 05, 2017, 04:45:23 pm »
I don't want to touch lead if I don't have to. Do you? Quite honestly, since you seem to have made so much research into a topic most of us couldn't care less about (hazard of using flux pens), I'm surprised you don't know the hazards of lead and soldering in general.
I keep them in a cup on my workbench, along with other, normal pens. As long as the cap is put on properly, there will be no fumes leaking from the pens.
Do you even know what flux is there for!? Alcohol is quite the opposite of flux!
Offline R005T3r
« Reply #8 on: August 05, 2017, 07:30:39 pm »
You get sensible to contaminants, especially if you have a predisposition to atshma in this case (which I have). Unforntunetely, exposure time don't quite play a significative role in sensitization because when you are exposed by let's say 60 seconds, you are exposed to a determinate concentration of contaminants and you start by developing a rash or some alike symptoms in the next 2-3 minutes. You are referring to contaminant's accumulation over time.
Sensitization cures by itself: if you get sensitized to a substance there's nothing to do, you have to go away from the contaminants and in time it goes away. If a certain exposure concentration threshold is met, you won't be able to tell if you are exposed to that precise concentration or not next time you are in the working envoirment (that's why it's called sensitization)
As for wearing gloves during soldering, it's at your discretion, but if you don't you just have to wash your hands and you are good to go. If you can make a shower, it's even better (because hairs can adsorb particles too!)
Holding your breath until the fume is away is not really something you should do, because you pollute your working envoirment and you are going to contaminate yourself (and sensitizing yourself) inevitably and building up contaminants on your skin, clothes etc.... Fumes of all kind have to be extracted (carried away into another place) or you should wear a gas mask.
As for the lead factor during soldering: it's not really an issue because lead fumes forms at it's boiling point which is 1.749 °C (3180 °F) and you are not supposed to reach those temperatures!
Offline ebastler
« Reply #9 on: August 05, 2017, 08:04:27 pm »
I don't think anybody answered this question in the original post:
I am not 100% sure what package you refer to. I assume you mean SOIC, i.e. 1.27mm pin pitch? In that case, my answer would be "no -- additional flux is not needed". Use a regular soldering iron tip (small chisel or pen style), and thin solder so you can dose it properly. Then solder like this:
« Last Edit: August 06, 2017, 05:46:34 am by ebastler »
Offline KL27x
« Reply #10 on: August 05, 2017, 09:33:48 pm »
Your solderwire has flux in it, too.
If you solder things, you can't avoid using flux.
Personally, I think you could find the same warnings on any type of flux.
Use a local fume extractor or fan, if possible. Pushing the smoke away where it can cool off and disperse is much better than letting it waft straight up into your face.
« Last Edit: August 05, 2017, 09:35:45 pm by KL27x »
Offline NivagSwerdna
« Reply #11 on: August 05, 2017, 10:43:36 pm »
I use something like http://uk.farnell.com/circuitworks/cw8200/dispensing-pen-rosin-flux/dp/130709
It's very useful when you have small pitch components.... definitely useful for getting rid of bridges.
I clean with IsoPropyl afterwards as there is some residue left behind.
(I've also got some flux gel but not got around to using it yet)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #12 on: August 05, 2017, 11:26:04 pm »
I use these , and refill them with liquid flux until the tip disintegrates.
The only precaution I ever take is if I'm doing a big lot of production  soldering, I have a fan blowing across the bench.
There is no issue handling leaded solder. Metallic lead is extremely unreactive.
Overall it is less healthy to use unleaded solder, as the flux vapours tend to be more irritating.
Day Job: Mostly LEDs
Offline agehall
« Reply #13 on: August 06, 2017, 08:24:05 am »
I think the theory is that you can get lead particles on your hands and unless you wash carefully afterwards, you can transfer those onto food and eventually ingest it (which is bad).
« Reply #14 on: August 06, 2017, 02:41:05 pm »
Thank you, i will try like this.
I like the idea of a fume extractor,
after its used where do you store it ?, dont the bad parts fall out, or you throw away the filter after usage ?
If the filter is not good anymore the bad parts will come out back.
Offline Wim_L
« Reply #15 on: August 06, 2017, 04:19:43 pm »
In theory, yes. lead-free solder needs a more aggressive flux, so that's what they put in the solder.
But if you're getting extra flux, many separate fluxes are now for the lead-free type anyway, as that's where the big volume is. So many of those flux bottles you find these days, even for use with tin-lead solder, are going to be the stronger, less healthy stuff (not that smoke from traditional RMA flux was healthy, but some of the new stuff is worse, and you can often notice a sharp acidic smell).
Offline mikeys
« Reply #16 on: August 06, 2017, 11:31:32 pm »
I have my soldering setup in the conservatory. Don't ask. I've had a flux pen out there I left in the sun for a while and apart from leaking a bit, there's nothing wrong with it. What I use for fume extraction is a desk fan to suck the stuff away from my nose and towards the window/door.
It's not as scary as it sounds, there's probably similar stuff on a bottle of household bleach. Just don't eat it or stick it in a bong and you'll be fine.
« Reply #17 on: August 10, 2017, 02:14:15 pm »
I soldered the 14pin DAC ( WM8521CH9GED ) to the DIP converter without flux,
the soldering gives some water like flood between pins ( it comes out the stannol ), what is that ?, i think it can short-circuit.
Normally i scratch all garbage away with my experiment boards, now its to small.
Offline agehall
« Reply #18 on: August 10, 2017, 02:43:04 pm »
Can you provide pictures? I'm not sure if we are talking about solder bridges or flux residue here...
« Reply #19 on: August 10, 2017, 03:09:50 pm »
I attatched a foto.
Suppose i go measure the pins, cant i blow the DAC up with the voltage coming from the multimeter ?
Offline ebastler
« Reply #20 on: August 10, 2017, 03:55:20 pm »
That's just the flux (resin) from the solder's core. It is non-conductive. You can clean it off with Ethanol (or similar solvents) if your prefer, but it will not affect the circuit's function.
Offline KL27x
« Reply #21 on: August 11, 2017, 09:25:51 am »
The resin is beneficial in the case you don't want to wash the board.
Flux works because it contains an acid which dissolves copper and tin oxides. But the acid and copper salts leftover will be conductive and acidic when exposed to water/humidity, and this could, indeed, cause problems on your board. The resin is there to encapsulate these salts in a waterproof clump. Some resins do double duty; when heated and/or dissolved in solvent, they are the main active acid. Such is the case with natural rosin flux (abeitic acid). But in many cases, there are stronger acids in the mix, too.
In certain "low solids" no clean fluxes, there are very little of these resins added for both esthetic appearance and so that test pads and connectors don't get obscured. The residue will be very slightly conductive, so they are truly designed to be used sparingly, in a controlled manner... as constituent of a solder paste or solderwire, for instance, to be used on very clean board/pads. Too much flux will cause a problem. If you are using such a flux for manual soldering/rework where you might slather liquid flux onto a board, that's fine, too, but depending on the application you may have to clean the board, after.
Hi solids and resin flux residue should be cleaned off high heat areas of the board, though. If left on a power transistor/regulator or the like, they are going to be acidic/conductive at high enough temp.
« Last Edit: August 11, 2017, 09:36:57 am by KL27x »
Offline tablatronix
« Reply #22 on: August 11, 2017, 01:39:59 pm »
I bought one of these cheapos
Been happy with it so far
https://www.amazon.com/gp/product/B008OC3VMU/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Never used flux before, It makes life so much easier, plus It helps with old protoboards and using up older solder with bad flux , i use it all the time now, just so I don't have to fight with a single connection for more than a second if its not wicking, Its like cheese just put it on everything first.
This says RMA flux, I always clean anyway, but you might want something else that is really forgiving about leaving it on.
« Last Edit: August 11, 2017, 01:45:32 pm by tablatronix »
« Reply #23 on: August 11, 2017, 04:18:23 pm »
So you clean the flux with  Ethanol also ?
Offline nanofrog
« Reply #24 on: August 11, 2017, 04:44:53 pm »
FWIW, I use liquid RA or RMA in a Bonkote BON-102* refillable brush pen **. Plenty of other methods to dispense it though, such as a brush bottle or nail polish bottle (brush is attached to the cap), needle bottle, or even dip an inexpensive artist brush in a small cup/bowl. Not only does it cost less, but it has more control than a disposable pen (or even refillable CW7000 pens).
MG Chemicals sells their 835 RA flux in hobbyist friendly sizes (100ml & 1L), and is available in the EU. This can be left on the boards in most cases if you wish.
* Bonkote only sells them in 5 packs, but some vendors will break them apart & sell individuals (~$15 for a single in the US).
** You can find counterfeit BON-102 pens on ebay.nl; the valve/guts may not work on these, but it's still usable even if you have to remove the them (just store it upright).
