Hello,
Recently I started doing some SMD soldering, so I bought a
CW8100 No clean flux pen.
The thing came with lots of warning about the affects it has. All are in
this MSDS.
For more background i'll say that I solder in my bedroom, while my door and a 1meterx1meter window are open, and the soldering station is 1 meter from the window, with a 12V DC fan sucking the fumes to the direction of the window (not necessarily making them go out of the room, just away from me).
I would be happy if someone who knows about would check the MSDS and tell me what I should and should not do. I am able to set up a more advanced air cleaning system if that is needed.
My other question is weather should I clean this flux after use in some way? Is it conductive? what about high voltage (230V AC mains)?
