I figured out I'm in need of taking flux seriously;
Yes, indeed, flux is essential for soldering, but good solder has the flux already included.
No. The
quality of the solder has nothing to do with whether it has a flux core or not. There is terrible quality flux-core solder, and there's top-quality solder with no flux core.
Frankly, when looking at solder made of good-quality metal, the type and quality of the flux core is what makes all the difference. A well-designed, high-activity flux core (like Kester 44) runs circles around a solder with inferior flux (like most Stannol I've tried).
In electronics, we basically never use wire solder without a flux core. But it's common in plumbing, for example.
Lots of SMT soldering techniques do require adding extra flux though.
Indeed. It's essential to certain techniques. (Heck, that's even true in THT soldering, for example in mass production. It also helps in manual THT work if your components are a bit more tarnished.)
Solder wick also contains (powdered) flux, but adding more flux often helps there too.
I thought it was made by coating it in liquid flux and drying it. I always assumed the powdery appearance was because of the wick getting flexed after the flux was dry, causing it to fracture.
But I totally agree, most wicks can be improved by adding more flux.
There are lots of good (and also bad and ugly) video's on youtube about the use of (extra) flux during soldering. Go watch them to see what a good soldering process looks like. (Hint: "GreatScott" is terrible at soldering. Avoid him at all costs when it's the soldering you are interested in.)
Absolutely! I love GreatScott's projects and explanations, but his soldering is awful!
Wetability is the same principle as with water.
If you pour a glass of water over a T-shirt it gets wet (and sometimes other nice side effects).
If you pour a glass of water over a raincoat it rolls of.
It's actually not like that at all!
A much better analogy would be a block of salt: where water comes into direct contact with the salt, it dissolves the surface. But where the block is greasy, the water cannot come into contact with the salt.
Soldering involves the solvent action of the molten solder. See the first video in the Pace tutorial series I linked above.
With soldering, there is always a bit of dirt and oxidized stuff on everything you want to solder.
Which is why it's always a good idea to clean your boards (and to the extent possible, components) with solvent (like alcohol) to remove contaminants. Then the flux can take care of oxidation.
In practice, the solder sticks to the clean other metals, but not to the dirt and rust, and a part of the job of the flux is to remove the dirt.
Solder doesn't "stick" like glue. It dissolves the substrate, creating an intermetallic layer between the substrate and the solder itself.
FYI, "rust" means red iron oxides specifically. We rarely deal with that in electronics. We deal with oxidation all the time in electronics soldering, but it's practically never
rust.
While flux can remove some contaminants, its primary job is to deal with oxides. It's best to remove contaminants prior to soldering.
I think the flux also lowers the surface tension of the solder (but I'm not entirely sure). But if it does, it is (a bit) comparable to mixing in a bit of soap with the water before you pour it over the T-shirt. (Although the flux does not dissolve into the solder, so it's a mediocre analogy).
I think it lowers the surface tension, but I think more in the sense that oxides (which form on the solder itself, too) have extremely high surface tension, and by eliminating the oxides, the flux allows the solder itself to contact the joint.
