Bonjour, where are you located? Any link to the website with this image?
The image is a variable shunt neon sign transformer to create a variable current at high voltage for testing or bombarding neon gas tubes.
In general shunted transformers are used to limit short circuit current, in arc lamps, neon signs, and microwave ovens.
Special laminations are used in production with a fixed shunt built in, or a separate lamination bar is inserted after winding after the other laminations are assembled.
As the lighting industry migrates from ancient arc lamps and gas tubes to modem LEDS these are used less and less.
microwave ovens also have evolved from a HV shunt mains transformer and diode to a modern SMPS inverter.
Thus these are more of historical interest, but still a very fine magnetic circuit example.
Bon chance,
Jon
