I thought I could wire their inputs in in parallel and use a 5v 5amp supply to power them and then split the battery pack up that I made and connect two cells in parallel to each charger pcb and then connect the outputs of the charging pcb in series to power my project. Would this work?
That will not work. It will work if you use 3 separate chargers, each one connected to a module.
If I were you I would just get a boost converter with CC limit, set the voltage to 12.4V, set the current to 2A and power it from 5V.
Hook it up directly to the output of the battery pack. The physics should take care of everything.
I'm curious if this would be a bad idea long term, do LI-ION cells get damaged if continuously trickle-charged ?
http://www.ebay.com/itm/-/371279559525
