The PNP transistors are connected backwards, so are behaving like 7V zener diodes. If the collector emitter connections are corrected, it should work, but it's also possible the transistors have been damaged, due to the reverse voltage. I recommend replacing the PNP transistors with new ones, connected correctly.
The schematic is also drawn in a confusing manner, which makes mistakes more likely.
