Author Topic: Fourier Series analysis of Triangular waveform  (Read 1226 times)
Offline khatusTopic starter
  • Country: gl
« on: February 13, 2019, 03:08:56 pm »
Fourier Series of Triangular waveform
this is the solution of Fourier series of a triangular waveform from the book Circuits and Networks: Analysis and Synthesis by Shyammohan S. Palli.
In this problem they have take the time period of the triangular waveform from  -π to +π instead of 0 to 2π.
Now, from -π to 0 the equation of the waveform is as shown below
and from 0 to +π the equation of the waveform is
Which gives
My question is,
If i take the interval from 0 to 2π.then from 0 to +π the equation of the waveform will be
and from +π to +2π the equation of the waveform will be
But this gives
which did not match with previous.My question is why they took the interval from -π to +π instead of 0 to 2π.
 I post my calculation here
« Last Edit: February 13, 2019, 03:23:45 pm by khatus »
Online Andy Watson
Re: Fourier Series analysis of Triangular waveform
« Reply #1 on: February 13, 2019, 03:57:00 pm »
Check the limits on your last integration and note that the upper limit is \$2\pi\$ - when you run the figures this should translate to \$(2\pi)^2\$, you appear to have used \$2(\pi^2)\$.
« Last Edit: February 13, 2019, 03:58:55 pm by Andy Watson »
The following users thanked this post: Wimberleytech
  • Country: gl
« Reply #2 on: February 13, 2019, 04:33:03 pm »
Thanks Andy Watson .silly mistake causes problem
Offline rhb
« Reply #3 on: February 16, 2019, 02:05:02 am »
Because the discrete Fourier transform is periodic over the semi-closed interval from (-Pi,Pi]  by definition.
I  had a very miserable couple of weeks at work because I overlooked the semi-closed part.
