Hi ,
I am from microcontroller background delving into FPGAs . I am trying to implement a seconds stopwatch and show the output on LEDs in binary. I have implemented a seconds counter . However , I am having trouble with the stopwatch.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity counter is
Port ( clk : in STD_LOGIC;
switch:in STD_LOGIC;
--inp:in STD_LOGIC;
leds : out STD_LOGIC_VECTOR (7 downto 0));
--leds : out STD_LOGIC);
end counter;
architecture Behavioral of counter is
signal count : STD_LOGIC_VECTOR(25 downto 0) := (others=>'0');
signal second :STD_LOGIC_VECTOR(7 downto 0) := (others =>'0');
signal startTime:STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
signal endTime:STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
begin
--Challenge 2:Switch timer
myprocess:process(clk,switch)
begin
if(rising_edge(clk)) then
if(count = 50e6) then
second <= second + 1;
count <= (others => '0' );
else
count <= count + 1;
end if;
end if;
if(switch = '1') then
startTime <= second;
endTime <= (others => '0') ;
else
endTime <= second;
endTime <= endTime - startTime;#not concurrent behaviour
end if;
end process;
leds <=endTime;
By definition a statements inside 'if' statements are concurrent but I doubt that is what is going on .
Also I am getting plenty of latch and combinatorial loop errors . What am I doing wrong?
