Author Topic: using negative linear reg for positive voltage  (Read 2314 times)
Offline mianchenTopic starter
« on: October 09, 2012, 03:09:32 pm »
i'm making a few (50) identical widgets that require +5v, ~50ma power supply. I only have 5 78l05, but 100+ 79l05. is there any potential problems if I use these 7905 as voltage reg? obviously I will connect the gnd pins of 7905 to the vcc of the widgets, and output pins to ground of th widgets.
I've tested it and it worked, but since i'm a noob, I'd like to ask before I design the pcb and start making the lot. thanks
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: using negative linear reg for positive voltage
« Reply #1 on: October 09, 2012, 03:11:05 pm »
It's possible, I can't remember the implications, probably that you loose your common ground but if this is not a problem it might well be ok.
« Reply #2 on: October 09, 2012, 03:56:26 pm »
No problem just remember a 7905 requires a little more capacitance on input and output, as they can oscillate if there is not enough. Refer to data sheet for recommended values.
Offline Short Circuit
    • White Bream electronics R&D
« Reply #3 on: October 09, 2012, 05:29:22 pm »
Anybody to service these widgets in the future will probably hate you for saving these 10 cents.
Offline mariush
« Reply #4 on: October 09, 2012, 06:43:57 pm »
I agree, not worth the price. You can get them the next day from Farnell.
You can get 50 of those for less than 9 pounds... maybe not 7805, but these would be just as good, for 50mA it doesn't matter: http://uk.farnell.com/nxp/nx1117ce50z/ldo-5-0v-1-25-sot223/dp/2057286
7805 are also cheap enough: http://uk.farnell.com/fairchild-semiconductor/ka78l05az/ic-v-reg-5-0v-78l05-to-92-3/dp/1014073
