I just purchased one of those Victor 3165 frequency counters from China.
For the most part, it works well for my purposes.
I'm concerned about measuring high voltages directly to the BNC inputs. (120 - 250V AC)
The specs say the A channel ( 1Hz to 50 MHz) is 1M impedance with a maximum AC/DC peak input of 30V.
The B channel (50 Mhz to 2.4 GHz) is 50R with maximum of 3V input.
Most of my measurements will be on the A channel.
The manual is not very clear, but somewhat addresses the measurement of higher voltages:
"When measuring high voltage or strong RF signal by cable input, cables should be
in series with large resistance to prevent damage. Wireless input of very strong signals should be measured in coarse mode to avoid damage."
So my questions are,
1. What value of resistor(s) would I need to measure 60 Hz AC line frequency? Would it only be a single resistor in series, or do I also need to add a second resistor to ground?
2. Not sure what they mean by "coarse mode", but I want to be able to measure the direct frequency output of my portable ham radios (2m, 70cm, 6m, etc.), which would be in the range of 5-10W RF output.
Currently I have a BNC coax to dual alligator clips, and my 100 MHz scope probes.
Any advice would be greatly appreciated. Thank you kindly in advance.
Duncan, VE3DMC
