Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Leakage through isolated linear supply causing MAX31855 error?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Leakage through isolated linear supply causing MAX31855 error? (Read 515 times)
ledtester
Super Contributor
Country:
on:
October 15, 2020, 03:48:33 am »
I'm using a LM317 to heat a heatsink. Attached to the heatsink is a K-type thermocouple which is being monitored by a MAX31855 module (ebay variety) and a Teensy. The Teensy is powered via USB.
I didn't use a thermal insulating pad on the 317 -- after all, I want it to heat the heatsink. I've noticed that if I connect a lead from my linear power supply to the 317 (either positive or negative) the temperature readings are way off -- even with no power applied and the power supply switch off.
I know the MAX31855 needs to be isolated. I guess though that my isolated linear power supply isn't isolated enough. I'm wondering what exactly is going on.
Logged
ledtester
Super Contributor
Country:
Re: Leakage through isolated linear supply causing MAX31855 error?
Reply #1 on:
October 15, 2020, 04:45:29 pm »
Well, I figured out something - apparently it was my ethernet cable.
Powering the laptop via mains vs. battery didn't make a difference, but the reading error went away once I unplugged my laptop's ethernet cable.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
