Author Topic: From no parts to decent stockpile, best approach?  (Read 775160 times)
Offline RAPo
Re: From no parts to decent stockpile, best approach?
« Reply #275 on: January 03, 2024, 08:27:09 am »
Yep, very handy, good components. You can store some of the bins like little books saving bench space.
However, two nitpicks:
1) please choose a uniform packaging format
2) make the IC components pack available again,
I know this is an old post... but it is Pinned...
I've had some luck with an Amazon seller that goes by EEEEE (or eeeee.shop ).
They sell Jelly Bean (very common) electronic components (Resistors, LEDs, Diodes, Transistors, Capacitors, ETC.) but they kind of Add Value in that they sell their components in individually closable containers and they have nice color coordinated labels with some useful simple information.  This really helps in the organization of the component parts from the start and they are nice and compact (do not take up too much space).
So if your new and want to quickly get some common circuit components, check them out...
Example below of their component kits.
(Attachment Link)
Offline 5U4GB
« Reply #276 on: January 03, 2024, 10:27:42 am »
I like EEEEEEEEEeeeeeeeee..... as well, it's just so convenient to have a few boxes of individually-labelled common parts you can get at quickly instead of having to go through drawers of stuff to find the 555 you were sure you had somewhere... maybe the next drawer down... or did I leave it on the workbench?  The other day I needed to terminate a Modbus (RS-485) chain and pulled a 120ohm out of the EEEEEE resistor folder without even stopping to think about where the pack of intended-for-the-purpose resistors might be at the moment.
The following users thanked this post: RAPo
Offline cosmicray
« Reply #277 on: February 20, 2024, 09:41:53 pm »
You'll never be able to stock ALL parts.
Challenge accepted.
I did a mental exercise concerning E96 resistors (and only SMD). The magnitudes (beginning at 0R0 and proceeding up to ~9M76) contained 768 unique values per footprint size, without even getting into thick film, thin film or ppm variants. A shop with a full set of reels much have a significant investment in resistors alone. It starts out small, but then it just grows and grows.
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
Offline armandine2
« Reply #278 on: March 03, 2024, 09:38:40 pm »
Re. de-soldering practice
... of course the haul of components from a pcb can be total, but unless you have noted the location and description of each component you may not be able to reassemble  :palm:
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Offline Krotow
  • Country: lv
« Reply #279 on: June 20, 2024, 10:00:42 am »
People with a lot of unused storage space can keep a heap of donor boards from obsoleted analog and digital electronics as well. I believe this approach would work especially well for developing countries. Few my latest prototypes and repairs was partially or fully "sourced" from obsoleted routers, laptops, DVD readers, monitors etc. Price of these parts for me was effectively zero.
Offline CaptainBucko
« Reply #280 on: June 25, 2024, 02:03:38 am »
I started collecting components around 1992, and have also worked in the industry. Here is where I am at the moment:
- Primary Supplier : LCSC.com, which is the component sales arm of JLCPCB. Although located in China, they are highly reputable, and have datasheets behind everything they sell. You can buy high quality (ie: Panasonic) or no name, its your choice and you pay the difference. Shipping is about $8 USD (the slowest option) and is tracked and reliable. I would rather buy the cheapest option from LCSC than the most expensive from AliExpress. As a backup, I will buy from Mouser. In an emergency, I go to local suppliers.
- Catalog : Run a big Excel sheet with a link to all parts I stock, where I stock them, and their corresponding datasheet.
- Jellybeans : I keep a kit of Jellybean parts that I use in every project. Common value R's, C's, Op-Amps, FETs, BJTs, Diodes, LEDs, etc, etc. Unless I really need to vary from that, I don't. I have corresponding KiCad parts as well. You can adapt a lot of reference designs to use your jellybeans on hand if you understand the basics. This really cuts down on the stock pile.
- Scrap Parts : To keep costs down, I try and find useful scrap. Raiding the eWaste bin has been great, particularly if you find industrial electronics which tend to use high quality parts. I will occasionally raid consumer grade e-waste, but I focus on high value items like AV receivers, and stuff with linear transformers, heat sinks, etc. However, I really only use scrap parts for high value, one offs. I don't both with Jellybean scrap.
Offline kiwiwsniper
« Reply #281 on: September 15, 2024, 11:02:28 pm »
Hi there, I'm new to the forums but been into electronics for years.
This thanks for all the people that put their time and effort into this thread before me as it was a long read.
For me my stockpile has been going on for years my spare BUDGET is low and I want buy Quality parts so I buy some parts now and others later on and in between I save and buy midrange lab gear. (I.E. Solder station, Multimeter, Power Supply, etc)
I have found my local electronics shop the best place to buy the “Jelly Bean Kits”.
Most of the people have talked about what to get or where from, how to store parts and how to Inventory them. (ESD protection is a can of worms but look into it as it can save you money)
Everything you can get you can get over time or next day. This all depends on your BUDGET and how much time you have.
After all you can get all the parts but without a way to use them and test them if one or more part is bad after you put it into the circuit then what is the point of this hobby?
EDIT: straight after I posted this I re-read this thread and had another thought about it.
If you need 1 part of x amount, then buy as Much as you need to get to the next price break.
E.G. if Part 1 needs a QTY of 7 for $3 each for a total of $21, but the next Price break says 10, then I buy 10 for $2.25 each for a total of $22.5.
I use the 7 Items and Stockpile 3 Items also I have saved $7.5 plus the time to get them if I need to replace the part later on
« Last Edit: September 16, 2024, 10:51:13 pm by kiwiwsniper »
Offline aboubkr90
  • Country: sd
« Reply #282 on: September 25, 2024, 12:49:12 pm »
I'd suggest e-waste to fill the main bulk.
Then buy specifics.
Offline coreykelley
    • website
« Reply #283 on: December 02, 2024, 12:29:26 pm »
Thank you for this detailed post!
« Last Edit: December 02, 2024, 12:32:02 pm by coreykelley »
Offline CRC
« Reply #284 on: December 26, 2024, 02:29:42 am »
I get lots of RF connectors and various stuff from ham radio swap meets. There is often tons of stuff there for almost nothing.
Offline wilfred
« Reply #285 on: January 02, 2025, 05:38:30 am »
don't desolder until you need something. Make some notes about what you have to help you find something but most things won't get used ever so you can spend a lot of time removing things you may never use. Larger things like heatsinks  and the attached transistors are worth removing if only to make the PCB take up less space.
Offline wilfred
« Reply #286 on: January 02, 2025, 05:46:12 am »
I trawled the Arrow website during their recent sale. I picked up some stuff like enclosures, wire, switches, panel lamps, heatshrink, banana plugs and sockets, binding posts, inductors. really anything that was too cheap to ignore that would complement the stuff I already had in my box-of-dreams (future projects).
Offline peter.andaluz@gmail.com
« Reply #287 on: January 22, 2025, 06:39:34 am »
Amazon had a pack that had a lot in it to get you going. I wont post the link in case it violates some rule
Offline Langdon
    • My website + My software
« Reply #288 on: February 15, 2025, 02:26:33 am »
Try Tayda Electronics
j.mp/tayda
bit.ly/taydalog (login page)
Though I don't recommend stockpiling.
Buy what you need.
Don't be a packrat!
My website used to be www.getpacman.gq
It is now www.langdonstaab.ca
"Low-tech solutions are beautiful"
« Reply #289 on: February 16, 2025, 10:41:18 am »
LCSC is better than Tayda IMO. I have bought from both, but if you were kitting up, spend $50 at LCSC and you will be surprised how much you can get.
Offline Langdon
« Reply #290 on: February 16, 2025, 06:25:37 pm »
LCSC doesn't sell everything.
Plus Tayda's DDP DHL Express shipping is great!
Let t represent the delivery time.
50h≤t≤84h
« Reply #291 on: February 17, 2025, 12:42:49 am »
LCSC is SLOW! However, my point was really about "Stockpiling" where delivery time is irrelevant - If you are trying to build up a common part inventory, which I have done over the years, LCSC supplies good known brands for excellent prices in quantities of 20 or 50pcs. While you are at it, you could also order some of there pill box storage containers (https://www. lcsc. com/product-detail/Component-box_WENTAI-1-Bu_C15603.html). I know many people spend money on "kits" from AliExpress, but IMO, the quality is dubious, and you end up with many values you are unlikely to use.
Offline lu1s.p
  • Country: mx
« Reply #292 on: February 17, 2025, 11:40:49 am »
Thanks so much for this help
King regards  ;D
Offline lu1s.p
  • Country: mx
« Reply #293 on: February 17, 2025, 11:49:42 am »
Thanks fot this advice mate,
grateful  ;)
Offline perumethu@gmail.com
  • Country: kw
« Reply #294 on: March 15, 2025, 03:49:08 am »
Hi again guys, and welcome to the next installment of beginners (played by me) asking the wise and omniscient professionals (that's you) stupid questions.
I'm a software developer trying to get into EE and circumventing 10 years of gathering parts and test equipment.
The first thing I did was build a workbench, and acquire the . Now onto the tedious part; components!
What is the easiest way to get a decent stockpile of components?
My main goal is to be able to prototype most ideas.
Is there something like the (now discontinued) Seeedstudio Open Parts Library but for everything?
I need resistors, caps, inductors, chokes, ferrites, crystals, TVSs, fuses, diodes/zeners/bridge rectifs, transistors, leds, triacs, voltregs, op amps, audio amps, logic ics, optoelectronics, some sensors, wire and connectors.
I'm tempted to make a 'reel to plastic bag' robot and make these kits myself if they don't exist.
Any ideas and pointers are much appreciated!
