Hi all,
I am looking to connect my FSR (flexiforce A502) sensors to my PLC using a +/-10V analog input module (B&R X204222). I just want simple circuitry right now to do initial integration with the sensor in my controls. I am using circuitry similar to the attached Arduino example (R2 is the FSR sensor), but making the following changes: the 5V pin would go to the +5V on the power supply, A0 would go to the B&R analog input +, GND would go to the GND (-) of the power supply AND the B&R analog input -.
As to not short the power supply, I will be adding a series resistor, but I'm unsure of how to determine my series resistor size. I attached an example of recommended circuitry from the sensor datasheet where a 100kOhm resistor is used, but since I am not using this op amp circuitry and only a series resistor how do I determine resistance I should use? (I will be using a +5V supply).
Thanks in advance!
