Erratum: On my FWB scopeshot above, I may have given the impression that one channel was inverted. This is not the case for the specific display shown. The necessary inversion is handled by the math subtraction. (On analog scopes this is generally done by inverting one channel and using the "Add" vertical display mode, which does the same thing as not inverting, and then subtracting in Math, as is done in the DSO.)
On the Rigol, channel inversion is indicated by a "not" bar above the Channel Number on the screen display.
