I purchased a new FDK Ni-MH "A" cell to replace the battery in an electric toothbrush (Oral-B Braun Professional Care SmartSeries 5000). In removing the original battery, I left the original tabs in place by carefully ripping the tabs off the battery terminals. Then when I put in the new battery, I placed it in such a manner that the original tabs would rest against the new tabs on the new battery with some tension--no solder used at all.
I fully charged the battery and test ran the toothbrush a few times with the new battery fully charged, about 6 to 10 seconds each time, and it ran fine each time. When I was just about to put the insides back in the housing, the display showed the battery needed recharging. It took 12 hours to fully charge the Ni-MH cell but only 30 seconds of usage to drain it. I measured the battery voltage to be 1.40 v.
Could the battery be bad? I purchased it from Digi-Key a couple of weeks ago; the date code is "SEP-2020".
Could this problem be due to not using solder on the battery terminal connections (perhaps intermittent arcing during motor vibration causes battery drain)?
" alt="" class="bbc_img" />
