Author Topic: Do I have DC here ? Or does this cap prevents it ?  (Read 1247 times)
Offline Frederico AcardiTopic starter
« on: August 16, 2021, 02:30:19 pm »
Hello, the question is in the image ;)
Thank you.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: Do I have DC here ? Or does this cap prevents it ?
« Reply #1 on: August 16, 2021, 02:38:04 pm »
No DC there if V2 is an ideal sinewave generator with no DC offset.
In the real world you might have some DC depending on the generator and if it has decoupling on its output.
« Reply #2 on: August 16, 2021, 02:53:30 pm »
It's not an ideal generator, but suppose I have a DC offset, it will still be present after the pot at this node ?
Offline rsjsouza
  • Eternally curious
« Reply #3 on: August 16, 2021, 03:00:47 pm »
Yes, but proportional to the position of the cursor of R2 - in other words, R2 is a voltage divider where the output voltage is proportional to the relationship between the lower pin and the cursor and the upper pin and the cursor.
Question 9 of the reference below contains a nice description of this scenario
https://www.allaboutcircuits.com/worksheets/potentiometers/
The following users thanked this post: Frederico Acardi
« Reply #4 on: August 16, 2021, 03:31:40 pm »
Thank you !
