Hi members
I am Faizan. I am designing a circuit for driving a voice coil linear actuator with R=18 ohms and operates fully at a 5V supply. I want to make a current source and sink circuit so that I can source and sink current from the voice coil to produce back-and-forth linear motion. Right now, I am using an op-amp with a transistor as a current source buffer which provides variable voltage supply by varying input voltage between 0-5V at op-amp input generated by ADC and it also varies source current according to voltage set.
But, to produce reverse backward movement, I need to place negative voltage on a coil or sink current from it after supplying it with 5V. How can I design a circuit to both source and sink varying current from it by varying voltages from 0-5V with a 2.5V split? The Howland current pump is the way but it will always maintains a fixed current regardless of the input voltage to the load? Thanks.
