as i want to make switching P-MOSFET from 60V supply, i need robust push pull bjt driver as suggested by bktemp here...
https://www.eevblog.com/forum/beginners/vref-voltage-amplification-circuit-please/msg980594/#msg980594i'm having trouble understanding his explanation for my particular objective, so here again to make a bit clear.
the main objective is to ensure during P-MOSFET ON period, Vsg is no more than 15V (or -15V Vgs) in any state of operation, hence Vg to GND cannot be lower than 45V to avoid damage to mosfet. secondary objective is the push pull NPN+PNP bjts driver must be capable of supplying and draining 1A to/from the mosfet gate for efficient switching. if i can pull Vg to 0V (gnd) without damaging the mosfet then its easy, but this Vg biasing is difficult to calculate. To get the 2 objectives done (Vg biasing and high gate charge/discharge current), we need to find proper Rc and Re value, this is why this thread is all about.
to make this easier, there are 3 state in the operation.
1) 0.png: initial condition, comparator output in low position, where all I = 0. Vg = push pull base = 60V (no problem here)
2) 1.png: when LM393 output goes high (15V), mosfet gate start to discharge from 60V to 45V. i know the push pull need to pull at rate of 1A during that time, so i drew the current flow in the picture, assuming the PNP in push pull driver is in saturation (hFe = 10), ie its Ib = 1A / 10 = 0.1A. the biggest trouble is, what is the leftmost NPN's Ie? and Ic? and hence how to calculate Re and Rc?
3) 2.png: when LM393 output goes low (from high), mosfet gate start to charge again from 45V to 60V. since the leftmost NPN is now off, i'm guessing Ie = 0, so i drew the current flow again in the picture. now it become easier, i think i can calculate Rc now, but not sure if my assumption is correct.
my assumption:
from state 3:
Rc = (60v - 45v) / 100mA = 150 ohm. is this correct?
but when i go to state 2 again, i'm not sure because Ie = Ic + 0.1A (from push pull's base), Ic is the problem... hence i cannot think on how to calculate Re. and Rc = 150 ohm seems like too low, since bktemp in the other thread suggested the value of 3Kohm, but then 3Kohm wont be able to charge mosfet gate at 1A, this is real conflict! please help. thanks.
