Author Topic: Function of a little dot on bobbin of a flyback transformer  (Read 662 times)
Offline khatusTopic starter
  • Country: gl
« on: August 12, 2019, 05:04:41 pm »
Hello guys i want to know function of this dot on bobbin of a flyback transformer.I guess it is for dot convention of transformer
when i remove first layer of sticky tape i have found it was wound in clockwise direction.
« Last Edit: August 12, 2019, 05:10:35 pm by khatus »
Offline Domagoj T
  • Country: hr
Re: Function of a little dot on bobbin of a flyback transformer
« Reply #1 on: August 12, 2019, 05:20:01 pm »
Marking for pin 1.
Online Ian.M
« Reply #2 on: August 12, 2019, 06:49:34 pm »
It wouldn't need a peg like that just to visually *identify* pin 1, so it must be intended to operate a sensor or engage with a hole in a jig for (semi) automated assembly to ensure the bobbin orientation is correct with respect to the coil winding machine, or for part orientation during (semi) automated board stuffing.
The following users thanked this post: Richard Crowley
