Having a choice to use a wrong fuse, no fuse or cancel the project, the best option is to stop the project. But since most people will take the risk, if you really must then use even a wrong fuse. Still at least some chance, not even a small one, of providing protection. Certainly do not go for no fuses.
The reason you need a DC fuse is not because an AC fuse will explode in your face. It’s about the ability to do their job. A 50Hz alternating current waveform hits 0A each 10ms. If arcing happens, a hundred times per second there is nothing to sustain it. With DC there is no such option: the fuse must ensure that the arc is never formed or quickly extinguished. This makes them more expensive.
The first fuse you mentioned has only 50A breaking capability. A short across 60V will instantly reach much more than that, if only the power supply can deliver.
You do not want to parallel fuses to protect a single line.(1) Surprisingly the primary conern is not their failure; contrary: they may blow below the expected current. Two 7A fuses in parallel are not guaranteed to carry 14A.(2) That’s because their actual limits vary considerably and so is current each of them may see. Two 7A fuses may in fact blow at 7.5A and 9A, and passing 14A through them in parallel they may see 8A and 6A, leading to premature trigerring. The other end of the problem, the risk associated, is not observing that you can’t parallel breaking capability and creating more points of failure. You can’t get 600A breaking from two 300A fuses: one of them dies first, exposing the other to the full 600A. And if you have two fuses, there is much larger probability at least one of them forms an arc.
(1) Not impossible, but you would need to go deep into statistics, understanding theory of operation and modelling to parallel them safely.
(2) No fuse is, but the probability of a 14A fuse blowing below 14A is acceptably low, since manufacturers have error margins. That’s why in this Littlefuse datasheet you can see that one rated for 7A will on average pass 10A without blowing.
