Author Topic: My First project finished. With video.  (Read 3577 times)
Offline DellyjoeTopic starter
« on: June 27, 2013, 07:57:00 pm »
hello everyone this is my first project.
There is the schematic
End here are the two videos, the switches on the right i need to fix i just kind of put them on really fast, so do not look at them.
Here is the music box in action
And here is what it looks like
umm like i said this was my first project something small but fun, and something that would take me more then a couple of days to make.
Joe
Offline kizzap
Re: My First project finished. With video.
« Reply #1 on: June 28, 2013, 12:13:48 am »
Is it just me, or should resistors R15-R18 and R32-R35 be connected between the base of the transistor and the op amp, with increasing values of resistance along the lot?
Current limiting is already handled by the resistor between the LEDs.
-kizzap
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline poorchava
  • Troll Cave Electronics!
« Reply #2 on: June 28, 2013, 06:18:53 am »
I think he just wanted 8 leds total per channel, but considering the Vce drop you can't run more than 2 in series from 6V power supply.
Offline dr_p
« Reply #3 on: June 28, 2013, 06:43:32 am »
Yes, but there are no base resistors on those transistors.
And there are extra resistors from the emitters to ground. I think these might limit the base current, since it's actually IBE, so the base current flows out of the emitter, but that will also affect the collector current going to the LED. I've never seen this approach before though. Maybe because it's wasteful.
Offline ttp
« Reply #4 on: June 28, 2013, 12:35:37 pm »
It makes sort of voltage controlled current source - LED current is proportional to base voltage.
ILED=(VB-VBE)/RE where VBE is about 0.65V depending on transistor used
Offline cthree
« Reply #5 on: June 28, 2013, 08:12:13 pm »
Congrats on your first project!! Add your country to your profile so we know where you are :)
Looks like it was a lot of fun and must have been very rewarding to see it work for the first time!
Some good advice above. You might consider moving your LED current limiting resistors R15-18 and R32-35 to the other side of your transistors and you should add resistors to the base of the transistors.
As an alternative design did you consider driving the LEDs in parallel using just a single low-side BJT per colour? You've got a lot of transistors in parallel there doing pretty much the same thing. It appears the LEDs just glow together and that you aren't looking for any sort of meter effect. Would lower your part count and simplify. I'm not sure if I didn't miss some subtlety of the design. Perhaps for Rev B?
« Last Edit: June 28, 2013, 08:14:45 pm by cthree »
« Reply #6 on: June 28, 2013, 09:24:11 pm »
Thank you cthree ,
i did have a great time making this project and cant wait to find a new one to start, i will add my country right now so everyone knows were im from.
i will look into simplifying my project.
thanks for everyone posting in this topic thanks for helping me out.
Joe
