Author Topic: problem in designing multi-stage amplifier  (Read 1463 times)
Offline massprogTopic starter
  • Country: ir
« on: January 20, 2017, 04:19:51 pm »
hi dears
I should design an amplifier as soon as possible and for this reason I got confused
amplifier description is : input resistor 250K \$\Omega\$ , output resistor 50 \$\Omega\$ , gain = 80 and minimum swing 3V
I know how to analyse amplifier and how them works.
I got confused that how should start design,what structure should I use and ...
thank you
Offline LvW
Re: problem in designing multi-stage amplifier
« Reply #1 on: January 20, 2017, 05:17:48 pm »
You can use BJT`s, FET`s, classical opamp(s), other amplifying IC`s,....
Any preference?
Offline dmills
« Reply #2 on: January 20, 2017, 05:19:14 pm »
Missing half the spec.
Frequency range? Noise performance? What 1/f corner? Supply voltage? Current consumption?
50 ohm output resistor or capable of driving a 50 ohm load, these are very different objectives....
Something jfet input feels right (High Z input), but it very much depends on the other parameters, this could be a single opamp maybe with an additional current booster, or it could be several pages of clever circuitry it depends.
73 Dan.
  • Country: ir
« Reply #3 on: January 20, 2017, 05:26:50 pm »
Any preference?
I should design simple bjt amplifier with description that I mentioned
  • Country: ir
« Reply #4 on: January 20, 2017, 05:32:28 pm »
73 Dan.
50 ohm output not load
supply voltage could considered 12v
I want design very simple not advanced design
thank you
« Last Edit: January 20, 2017, 06:02:17 pm by massprog »
