Hey all, I'm trying to layout a board for LED light that will consist of alternating rows of red, green and blue LEDs. My current layout is strings of 8 LEDs in series, with 3 RGB groups, for 72 LEDs total. For heat dissipation reasons, I'd like the final board to be aluminum, and to make that affordable, my board needs to be 1 layer. What I've discovered is, if I need to route both a positive and negative terminal for each string of LEDs, a 1 layer board is impossible if I have more than 2 RGB groups, so I've been exploring whether I can make my design work with a shared cathode or anode, but I'm also hoping to use constant-current drivers rather than series resistors to drive the LEDs, and I'm having a hard time understanding whether parallel circuits with a shared ground or voltage source can maintain different voltages. I appreciate any input on my plan or illumination of the issue. Thanks!
