If the kit fails to work first go then you learn a lot troubleshooting it.
One of my earliest kits was a Heathkit 19" color television. I was 13 y.o. It was obviously a large, complex kit. Some boards you had to assemble, some came assembled.
In any case, when I first powered it up, magic smoke came out. I found the damaged component on the main board and ordered a new main board to assemble. It smoked the same way. After much time upset, and much time debugging, I finally worked out that the one un-keyed cable harness in the whole kit was in backwards. After calibrating the beams, the TV worked perfectly for 25 years until my folks tossed it, working, for an LCD jobbie.
The Heathkit manual had a detailed section on theory of operation. I learned a lot from that. Also, you really can't assemble a television without learning a bit how they work. In particular, they require calibration of the RGB beams by moving the control yolk and some fixed magnets. That means you can't escape without learning at least that there are beams.
Well, were beams. Today, all that knowledge of how a CRT TV worked is grampa-level, like knowing how to chink a log cabin.
