Your spec keeps on changing.
First it is 100MHz, then 100MHz bandwidth, and I suspect even that isn't correct (it certainly isn't accurate).
First it is single-ended voltage, then you introduce differential current.
You should do research on "differential transimpedance" and "reconstruction filter".
