Hello all! First time here, but have been following Dave's videos for quite a while, figure this was the place to come with my burning questions!
I'm trying to make a very basic miniature wind turbine to charge a battery. I'm using a small DC motor attached to the turbine as my generator. Just giving the turbine a spin with my hands I can get anywhere between 100-250mV. Just for fun, I'm also playing with those little TEC units which also give quite small voltages, usually around 100mV or lower.
My question is, how do I make this usable? I've done a fair bit of Googling and playing with my multimeter and I've come up with some ideas, maybe you all can tell me if I'm on the right track.
What seems to be the best idea for storing electricity with very low voltage is to have a bank of capacitors wired in parallel. For simplicity sake, let's say I have 10 caps each getting 100mV, which would give me a total 1V (I'm aware my total capacitance will go down in this configuration). Lets say once each cap reaches 100mV (or perhaps at a set time interval, regardless of cap charge), they switch to a series wiring and thus all dump their charge in one go, giving me 1V to my destination. My question here is, how on earth do I wire that? It's mind boggling!
Secondly, it took me ages to figure out that my problem even keeping a cap charged was the cap draining back to the source. For instance, I would attach a capacitor to a small solar panel, and if I exposed the panel to light, the cap would charge. If I covered the panel, the cap would consistently drain quite quickly, if I unplugged the panel, the cap stayed fairly consistent in charge. My conclusion was that when the panel is attached but not receiving enough light to generate hardly any voltage, the cap starts draining back into the panel, until the very small voltage output of the panel more-or-less matched the charge of the cap. Is this correct?
Now that I think I figured that out, let's simplify everything: 1 cap and 1 power source (turbine, solar, whatever). I'm only getting around 100mV. How do I keep the cap from draining back into my turbine or solar panel once the source stops generating? At voltages this small, even a Schottky diode would be useless. If I'm understanding things correctly, once I figure *this* part out, then I can move on to figuring out how to wire them up with a switch or timer that will flip the configuration from parallel to series every so often.
I know that's a long post, but I tried to be as detailed as possible!
Any help would be greatly appreciated.
Thanks!
- Tommy
