Author Topic: Delete Delete Delete  (Read 3176 times)
Offline The_Almighty_Bacon_LordTopic starter
« on: February 11, 2017, 11:10:20 pm »
« Last Edit: August 16, 2020, 07:25:25 pm by The_Almighty_Bacon_Lord »
Online helius
Re: General Causes for Flicking CCFL Backlight, and How to Repair?
« Reply #1 on: February 11, 2017, 11:43:59 pm »
Of all those components, the tubes are the most obviously life-limited (was the display already used for several years?) Over time the cathodes emission degrades. Since there is no heater, they then have difficulty lighting when cold, leading to flicker but not much light.
The inverter has switching transistors that could fail short; I don't know if the transformer often fails.
Online Monkeh
« Reply #2 on: February 12, 2017, 12:16:56 am »
Have a listen and a feel around the ends of the tubes. Sometimes the leads come off.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: February 12, 2017, 12:34:39 am »
Could also be HV breakdown starting to happen somewhere, but most likely aging tubes.
Day Job: Mostly LEDs
Offline Cliff Matthews
    • General Repair and Support
« Reply #4 on: February 12, 2017, 01:22:09 am »
If I recall ELO makes good touch screens. You could retrofit this to LED. Several hands-on examples exist on YTube:
https://www.youtube.com/results?search_query=CCFL+Backlight+conversion+to+LED
Online helius
« Reply #5 on: February 12, 2017, 01:23:42 am »
I've never heard of "HV breakdown" before.
Partly because there are no heaters to pre-warm the cathodes, starting a CCFL takes high voltages, up to 3kV. That can be enough to blow through the insulation between the transformer windings. Since you can't see through the transformer, it's hard to detect this. The result would be that the output voltage doesn't rise high enough to start the lamp.
Online helius
« Reply #6 on: February 12, 2017, 05:35:11 am »
A CCFL isn't "filled" with mercury: the amount is a few milligrams, and you would have to physically bend it for it to break. Inverters with a different design will have transformers with different properties; if the circuit doesn't resonate it simply won't work.
Offline soul40k
« Reply #7 on: February 13, 2017, 01:12:25 am »
My best advice is to never trust capacitors. Even if they are not bulged, they could still be far too degraded to do their job properly.
