Author Topic: Trying to find 1 v trigger relay  (Read 946 times)
Offline HappyhopperTopic starter
« on: August 17, 2019, 10:46:30 pm »
Anyone know of a read relay at say 1 .v trigger?
Offline ledtester
Re: Trying to find 1 v trigger relay
« Reply #1 on: August 17, 2019, 11:52:04 pm »
A bipolar transistor "triggers" at 0.7V and that can be used to drive a relay.
What's your ultimate goal?
« Reply #2 on: August 18, 2019, 10:12:20 pm »
To use a mp3 player as a control for a 3 volt motor thank you for your help
Offline ledtester
« Reply #3 on: August 19, 2019, 01:30:41 am »
I'm going to guess that you want to trigger a relay when the audio level is greater than a certain amount. If that's not the case you gotta give us more details on what you really trying to do.
Here's a very straightforward idea:
- get a LM3916 and a 555
- build the standard VU-meter circuit that is described in the datasheet; there is also an instructable here:
https://www.instructables.com/id/LM3915LM3916-VU-Meter/
- the LM3916 VU-meter will operate from it's own supply, like +5V
- wire up the 555 as a "monostable multivibrator" which will activate a 5V relay on its output;
https://www.elprocus.com/monostable-multivibrator-using-555-timer/
- use one of the LED outputs of the LM3916 to activate the trigger input of the 555; which one you choose will determine the trigger level
Offline Audioguru again
« Reply #4 on: August 19, 2019, 02:21:12 am »
The LM3915 and LM3916 are obsolete, not made anymore and not in stock at Digikey.
The LM3914 is still made and available only in a tiny, impossible to solder, surface mount package.
Offline jeroen79
« Reply #5 on: August 19, 2019, 07:26:24 am »
Can you elaborate on this?
Offline soldar
« Reply #6 on: August 19, 2019, 07:37:54 am »
Why do you open several threads and so cryptic?  Why don't you explain well what you want and all in one thread? Please don't waste people's time!
I would like to use my mp3 player as a signal generator to relay a3volt power supply , was going to make my own by use of a read relay question is there a better way
Prate
