Author Topic: Generate runt pulse.  (Read 1878 times)
Offline perfect_disturbance
« on: July 05, 2013, 07:22:51 pm »
I was reading the users guide for  the Rigol DG 4000 series function generators and trying to figure out how Dave generates the periodic runt pluses he uses to test refresh rate in some of his oscilloscope review videos.  Does anyone here know how to do that?
Offline AndyC_772
Re: Generate runt pulse.
« Reply #1 on: July 05, 2013, 07:42:18 pm »
Generate two streams of pulses with a microcontroller or CPLD, which are usually the same but occasionally differ. Join the two outputs together with a pair of resistors, and probe the point where they join.
Offline jpb
« Reply #2 on: July 05, 2013, 08:51:44 pm »
There are various scope testing boards that will do this - e.g. Rigols DS6000:
http://www.batronix.com/pdf/Rigol/UserGuide/DS6000DemoBoard_UserGuide_EN.pdf
otherwise arbs with a sequencing capability can do this easily (e.g. Agilent 33500 series or ones with a variable clock such as the Tabor WW5061).
« Reply #3 on: July 05, 2013, 09:18:38 pm »
I thought he was doing this with a Rigol DG4000 series but apparently that's not the case.  I guess I'll have to build my own :).
