Author Topic: generating gerber files with drill in altium  (Read 2173 times)
Offline manubaliTopic starter
« on: June 14, 2017, 11:08:50 pm »
hi, i am working on nixie clock project, i have finished pcb layout in altium and i have sent gerber files to manufacturer for quotation, i got reply that they need gerber files with drill instead of cam file, i am totally newbie with altium and pcb designing. so, can anyone tell me how do i generate them thanks.
Offline Dave
  • Country: si
  • I like to measure things.
Re: generating gerber files with drill in altium
« Reply #1 on: June 14, 2017, 11:57:35 pm »
File -> Fabrication Outputs -> NC Drill Files
It's going to generate a CAM file, out of which you need to export the drill gerber. The process is the same as for the other gerbers after that. The final result is a .txt file.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
The following users thanked this post: manubali
« Reply #2 on: June 16, 2017, 05:11:28 am »
thanks everyone, waiting for pcb now.
