Hello.
I know, title is a bit misleading, but I simply don't know, which term applies to this correctly.
Situation is as follows:
I have +-5V supply "on board".
I need to generate square pulses at output, at low frequency (50-200hz), but output should also go negative related to ground pin - output should swing from -2.5V to +2.5V. Current up to 5A.
As far as I understand this, I need two mosfets, N and P channel, and have to drive them sequentially. For that I plan to use MCU with hardware PWM generator, with dead time and all bells and whistles.
However, while with N mosfet everything is simple, I can't figure out, how to deliver negative voltage at P mosfet gate, from the MCU, which runs from +5 volts.
Any ideas?
(no transformers at input or output, please)
