Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Opal Kelly 7310 Pin Mapping
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Opal Kelly 7310 Pin Mapping (Read 2764 times)
loftusmi
Newbie
Country:
on:
February 20, 2024, 01:16:33 pm »
Hello,
I'm designing a PCB to interface with an OpalKelly XEM7310 that I plan to configure with some open source firmware. I'm trying to connect the PCB traces to the correct pads for the PCB/XEM7310 pin connector so that the firmware will not require modification for different pins. However, I'm not finding an I/O pin map for the XEM7310 online like one might find for a microcontroller. Opal Kelly does explain which MC1/MC2 pin that the FPGA maps to, but I don't see where it says which MC1/MC2 pin is which on the XEM7310 (nor do I really understand what MC1/MC2 means). Am I misunderstanding something about the way FPGA pins work or have I not found the proper documentation yet? If it's the latter case, does anyone know where I can find the pin map that I'm looking for?
OS Firmware Documentation:
https://intantech.com/files/Intan_RHD_XEM7310_interface.pdf
PCB/XEM7310 pin connector:
https://www.samtec.com/products/bte
Opal Kelly XEM7310 Pin Reference:
https://pins.opalkelly.com/pin_list/XEM7310
Logged
loftusmi
Newbie
Country:
Re: Opal Kelly 7310 Pin Mapping
Reply #1 on:
February 20, 2024, 07:14:44 pm »
Figured it out! I just needed to click on one of the table rows on the Pin Reference site. Then the map that I'm looking for appears above.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
