I'm getting a little confused with the basics, more the equipment rather than the result.
I've managed to blow the mA fuse in both of my multimeters, but according to my working out, it should have been fine.
I'm also getting a little confused as to how to set up my power supply (which might be the cause of most of my problems).
I simply wanted to set the power supply to replicate say 2 x 1.5v batteries.
Doing other experiments, I found setting the amps to 0.5 seemed to be a good place, as my experiments only seem to draw as many amps as they need. So I set it like
and as soon as I turn the output on with nothing connected, the amps drop to 0
I create the simplest of circuits, 3v, 470 ohm resistor (measures at 469.2)
I turn the power supply output on and the amps say 0.004, I take that to read 4mA ?
So to find the actual current, 3v / 469.2 ohms = 0.0063, so the current is 6mA
I measure the current by putting the meter in series
I have to use the Amp input on my meter as I've blown the fuse on the mA
This shows as 0.006 which is what ohms law says it should be.
While I ended up with the correct result, I'm not sure why I blew up both mA fuses, and I'm not sure why my power supply only shows 4mA. I just want to make sure I fully understand everything that's going on before I go onto the more complex stuff.
OK, I'm initially setting my power supply at 500mA, but the second I turn the output on, it drops to zero, and when measuring the current, it was zero until I touched the leads, then it went to 4mA.
One meter has a 250mA fuse, so if it somehow got the 500mA, that explains how it fused, but I don't understand how it would have got it, the other meter has a 1 amp fuse which shouldn't have blown, even if it did get the 500mA.
This was something I was reading in a book that I thought I'd spend 5 mins trying as I hadn't measured current before. Two hours of confusion, then I check fuses in both meters
