Author Topic: hardware or software?  (Read 2095 times)
Offline alectoTopic starter
« on: June 14, 2016, 01:10:28 pm »
In a few words : I build an led cube(I know...original ;)) 3x3x3
I have 9 common cathode columns of 3 leds, each column is switched by NPN (BC337, 10k on base, load on collector, emitter to ground ) and 3 common anode levels of 9 leds, each level is switched by PNP (BC327, 10k on base, load on collector, emitter to 5v)
the logic is provided by a PIC16F690 and me with PickIt2 MPLAB and ASM...(unexperimented experimenting beginner)
The All is alimented by a 9v wall wart regulated to 5v with an LM7805...
The cube worked all right for 3 weeks ...my program was too heavy, badly implemented but it worked !
So last week I wrote a new program, tried it ...and I was a happy programer...it was way lighter...I added software pwm...made some tests, a few animations...and proud of myself decided to turn it off...but 2 minute later I turned it on(yeah just to watch it once more...so sad) and there it started...
Now when I turn it on, it does strange animations...then a few minutes later it seems to "stabilize" and run my program correctly
If I try to modify the program during this "strange phase", the result is different... but still not coherent
but if I wait for it to stabilize, every modification applies immediately and correctly...
What I did so far :
  • checked  voltages...seems ok
  • checked for bridges or short...none
  • replaced the PIc...no change
  • added 10k between MCLR an VCC(even if deactivated by software config)...no change
  • added 0.1µf between VDD an VSS...guess what...no change
  • uploaded my old badly implemented program...still this strange (but slightly different) behaviour
  • today on a breadboard I redid the circuit, except I used 2 ULN2803 to drive the 9 columns...and yes...still strange
While writing this, I realized that it must be software...I just don't get why when I reverted to my ancient code, the bug remained...(or appeared??)
hardware or software...maybe neither, maybe just me....
anyway if you have any suggestions...a tired amateur thanks you in advance
Re: hardware or software?
« Reply #1 on: June 16, 2016, 02:52:51 am »
I'm guessing HW although it's hard to confirm without a scope.
Thinking it's a power rail issue from the IC coupling state switching transients into the power rail.  :-\
What bulk capacitance value have you used after the PSU?
Offline jdraughn
« Reply #2 on: June 16, 2016, 07:47:34 am »
Sounds like you may have an overflow happening in code.
Offline Chris Mr
  • Where there's a will there's a way
« Reply #3 on: June 16, 2016, 08:56:44 am »
If the running the old code that worked ok doesn't fix it then I would say hardware
Presumably you have resistors in series with the LEDs?
Offline danadak
« Reply #4 on: June 16, 2016, 09:41:33 am »
Post the code and a schematic.
Regards, Dana.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #5 on: June 16, 2016, 10:07:56 am »
You mention the new code is 'lighter'... does that mean 'brighter'?
Perhaps your new code has increased the 'on time' of the LEDs - pushing the current consumption of the circuit toward the edge...?
Don't ask a question if you aren't willing to listen to the answer.
