Author Topic: 12V relay back feed  (Read 751 times)
Offline MillsnerTopic starter
12V relay back feed
« on: February 08, 2022, 04:48:11 pm »
Hello, new to forum.  Trying to wire up an override switch for my electric fans on my hot rod but for some reason I keep getting back feed from the battery circuit to the ignition circuit on my override relay.  I can tell the back feed is coming from the 85/86 side of the override relay as when either side of this is unplugged, the back feed stops.  Also if I unplug the 30 on the override relay this will also stop the back feed. Looking for some help on how to properly wire this up.  I want the fans to work on ignition normally but when i push the fan override switch, I would like that fan relay to then be powered off of battery power.  I have attached a quick schematic.
Offline Terry Bites
Re: 12V relay back feed
« Reply #1 on: February 09, 2022, 08:50:28 pm »
The Truck Forum is not here anymore.
